New flywheel, old clutch
The new 427 small block goes in the car this weekend. I decided to go with a lightweight aluminum flywheel, but I'm using the Centerforce II clutch and pressure plate that came out of the car. Anyone have any suggestions regarding what I should do to freshen up the surface of the clutch disc that mates against the new flywheel?
My concern will be how long the Centerforce II will last behind a 427. The Centerforce Dual Friction would do well.
JIM |
I would clean the components with brake cleaner before it goes in and just run it. Probably a good idea to drive some normal stop and go for a couple hundred miles to get the disc and flywheel well seated before hammering the sh-t out of it.
A NEW 427 SBC, sounds like an expensive project. My Fidanza flywheel ran me $400. First engine was the modified 327, new clutch OEM 4 speed. Second engine a built 357 with a Tremec. new clutch. Third engine S/Cing the 357, it got a new puck type clutch plate and used the same pressure plate. Your are almost done, later on you won't regret spending the extra for the right clutch set-up. T
Originally Posted by 427Hotrod
(Post 1596353359)
JIM |
The DF is essentially the same as you have now with an improved disc. I don't think you have the added centrifugal weights that some folks think cause issues.
I've run them several times without any issue. My BBC 427 did well with it even on slicks yet pedal pressure was very reasonable. If you don't use all that power/torque or your tires don't hook up you'll be fine I suppose. If the disc is in decent shape it will work fine on the new flywheel. Nothing needed. JIM |
I reused my CF with a new flywheel when I did my engine swap. No issues at all.
(Post 1596357370)
The fresh grinding marks left on the new flywheel will "dress" the used disc within a very short period of time....just make sure no greasy fingerprints are on either piece.
Originally Posted by drwet
(Post 1596358126)
The Centerforce II has the weights. The CF I does not. I have used both over the years with good success. Nothing with the torque of the 427, but Centerforce lists the same part number for a small block and a big block. If it works behind a 427 big block, it should live behind a 427 small block if I don't do nothin' stupid. :D
Can you just get a DF disc these days without buying pressure plate too? I know you can from other MFG's. But as you said...try it and see if it works. The DF worked well up through the 700+ HP range even with my 540....but couldn't handle it when we moved it into the 800+ range. JIM |
I put a Centerforce dual friction behind my 496- not many miles yet, but it seems ok. I like the pedal feel. Very little more than stock.
I had to do the full setup on the pivot ball, and cut about .030 off the ARP flywheel bolt heads (lightweight flywheel). |
(Post 1596361851)
Cool...couldn't remember the differences. Then I guess main difference in the II and the DF is the hybrid disc of the DF? (which to me is a good thing).
(Post 1596357370)
No one else uses those weights, and I feel it's a gimmick at best. More of an issue than a solution to a non existent problem. |
The Centerforce ll will work fine. And, yes, the Centerforce l does have weights. They both use the same disk.
Originally Posted by gg521
(Post 1596369873)
I've keep hearing about the vibration problems but mine have been good. |
(Post 1596368950)
800 HP??! Wow. I'm thinking you've got bigger problems than clutch slippage. I'd be happy to see 500HP.
Next went to McLeod Soft-Lok which has been great. It's rated for the 1100 HP range....but I'm in the 1350+ HP range now and it's doing pretty well so far..... JIM |
(Post 1596375931)
LOL...yeah had to upgrade clutch a couple of times. Moved to a McLeod dual disc with added base pressure. NEVER slipped and hit HARD. Tough on parts.
2 Attachment(s)
It's a custom built Dana 60 made into an IRS setup. It has 1480 series solid u-joints, 3.5"x.134 wall halfshafts and Tom's outer stub axles.
JIM |
