Lingenfelter High Flow Direct Injection K-DI Kinetic Nozzle Geometry Fuel Injectors
Check Out The Video Below!
Applications: High horsepower GM Gen V V8 and V6 direct injection engines including LT4, LT1, L86, L83 and LV3 E85 conversions of GM Gen V V8 and V6 engines 2014-2017 C7 Corvette LT1 2015-2017 C7 Z06 Corvette LT4 2016-2017 Camaro SS LT1 2016-2017 CTS-V LT4 2014-2017 Silverado and Sierra with 4.3L LV3, 5.3L L83 and 6.2L L86 engines 2015-2017 Suburban, Tahoe, Yukon and Escalade with 5.3L L83 and 6.2L L86 engines Injectors sold individually These high flow gasoline direct injection injectors are specifically designed for use in the GM Gen V V8 direct injection engines or LT engines. At 27 grams per second flow rate these injectors provide the needed fuel flow for high horsepower applications without having to resort to auxiliary fuel systems. These injectors feature Nostrums patented K-DI kinetic nozzle geometry which provides high flow rates without sacrificing atomization. Spray targeting is designed for optimal combustion quality. These features combined with the supplied injector characterization data this insures that these injectors will perform well at low RPM light load idle all the way to high RPM peak power/load conditions. The injectors are also E85 compatible allowing higher output engines to take advantage of the availability of E85 fuel. Patented K-DI kinetic nozzle geometry that provides high flow with short liquid length & small fuel droplets Spray targeted to produce the specific spray plume shape for the GM Gen V V8 engine's combustion chamber and intake charge motion Optimized spray plumes, controllability and response for easy integration Built & tested to OEM durability & performance specifications Flow tested, sorted and marked by flow rate for improved injector matching Flow characterization data is provided for calibration purposes Benefits: Easy installation High flow rates Allows E85 conversion of stock and modified L86, LT1 & LT4 engines to provide an easier and more cost effective way to obtain higher octane pump fuel This product allows tuners to increase HP w/o sacrificing full range performance Flow characteristics can be easily calibrated with aftermarket tools using supplied data Eliminates the need for secondary fuel systems Specifications: Rated flow of 27 gram/second at 10 MPa - 122% more flow than the production L83 fuel injectors - 67% more flow than production LT1/L86 injectors - 52% more flow than production LT4 injectors - E85 compatible K-DI is a registered trademark of Nostrum Energy Here is a link to them on our website: https://www.lingenfelter.com/PROD.ht...7#.WldzdY1y4dU |
