Performance engine parts new or 100 miles
1 Attachment(s)
So I just bought a crate LS3 and No longer will be needing this stuff.
Eagle H Beam Rods Summit sells for $550ish New assembled in short block never ran stock LS1 dimensions good for 750hp $400 SLP performance Oil Pump #55001 New just mounted on short block new $180 $150 Comp 3 bolt hydraulic cam NEW Installed but never turned! 54-000-14 which means custom order. Gross Valve Lift INT=.610 EX=.615 Duration at .050 INT=242 EX=248 . 110 Lobe Seperation. 108 intake center line. INT open 13 deg BTDC Closes 49 deg ABDC EXT opens 56 deg BBDC and closes 12 deg ATDC $300 Water pump 500 miles only water has run through it no antifreeze $50 Speed Engineering Pushrods Chromoly Steel 7.4" .080 wall 100 miles $70 Lifter trays 100 miles with Two 1/2" holes drilled in each tray for oil return $30 Ls1 crank 24x .010 under on mains .020 under on rods. Polished out. $225 LS Aluminum 5.7 pre 2000 no groove rear oil galley on block. 3.898 bore but needs to go .005 over, deck surface needs to be skimmed. $200. LS Aluminum 5.7 out of my 2002 Vette so it's an LS6. 3.898 bore but needs to go .005 over and mains need line bore. $250 2002 Vette exhaust Manifolds Perfect $150 text is great, for pics 845 260 3050 parts in Lower NY Buyer pays shipping. IF AND WHEN USING PAYPAL USE THE FRIENDS AND FAMILY OPTION SO I DONT GET CHARGED FEES! THANK YOU Frank |
Originally Posted by Frank O'Brien
(Post 1596356319)
New in the box ARP head studs 3 length kit 12 point(#234-1110) 2003 and prior block . $230
Frank Thanks. |
Stand corrected. 6 point kit
PM sent on the heads. :thumbs:
Ttt
Bump
TTT New Items
Ttt
daily bump
(Post 1596356319)
Eagle H Beam Rods Summit sells for $550ish New assembled in short block never ran stock LS1 dimensions good for 750hp $400 LS6 intake with injectors and fuel rail $350 SLP performance Oil Pump #55001 New just mounted on short block new $180 $150 Comp 3 bolt hydraulic cam NEW Installed but never turned! 54-000-14 which means custom order. Gross Valve Lift INT=.610 EX=.615 Duration at .050 INT=242 EX=248 . 110 Lobe Seperation. 108 intake center line. INT open 13 deg BTDC Closes 49 deg ABDC EXT opens 56 deg BBDC and closes 12 deg ATDC $300 Water pump 500 miles only water has run through it no antifreeze $50 Speed Engineering Pushrods Chromoly Steel 7.4" .080 wall 100 miles $70 Lifter trays 100 miles with Two 1/2" holes drilled in each tray for oil return $30 Ls1 crank 24x .010 under on mains .020 under on rods. Polished out. $225 LS Aluminum 5.7 pre 2000 no groove rear oil galley on block. 3.898 bore but needs to go .005 over, deck surface needs to be skimmed. $200. LS Aluminum 5.7 out of my 2002 Vette so it's an LS6. 3.898 bore but needs to go .005 over and mains need line bore. $250 2002 Vette exhaust Manifolds Perfect $150 text is great, for pics 845 260 3050 parts in Lower NY Buyer pays shipping. IF AND WHEN USING PAYPAL USE THE FRIENDS AND FAMILY OPTION SO I DONT GET CHARGED FEES! THANK YOU Frank |
Bump
Texted about intake
Frank is a stand up guy on here for parts. I paypal'd him for the LS6 intake and received it as described and in a timely manner.
PM'ed
Tried to PM - your mailbox is full :(
The thread is a year old. He seems to be long gone.
No posts by OP in this thread in over a year. Closed but can be reopened if OP reports items are still for sale.
