Drivers side door won't shut
Drivers side door won't shut on my 2011. It shuts, but is not grabbing the latch and holding it closed, just pops back to open. any ideas?
I oiled it, to no avail.
Try pressing the "Open" on the door key pad, it should release the locking cam where it will close and lock.:thumbs:
Originally Posted by cmonkey713
(Post 1596364728)
I assume that you have indexed the windows. If not, the procedure is in your owners manual.
Tom |
Is the window indexing? Did you try lowering the window and then closing?
Originally Posted by Mad*Max
(Post 1596365576)
Door latch activator is internal bound up.
https://www.corvetteforum.com/forums...oorlock-1-.jpg If you can't get it unbound by lubing it with spray silicone spray, then you may have to pull it from the car, pull it apart, and clean and re-grease the parts isntead. |
Have you tried making sure the floor latch is fully down?
It may take a few pull-ups and let slap down to do it. eta: make sure there is nothing under the handle to keep it from fully engaging. |
Thanks Dano, will try that if what OWC suggested doesn't work. Dano, any idea what the part # is for that in case i have to replace it?
Got it removed, now if i can only figure out how to remove the top so i can clean the gear and stuff inside. Any tips?
good luck on the fix, will be interested how you do it...
