1985 left dash turn signal not blinking
on 1985 my left dash turn signal (which was working) now stopped blinking...it stays on and does not blink. the right one is fine. would this be the flasher and where is the drivers side flasher located? is it easy to get to and replace? i am NOT a mechanic but would like to try without ageing myself. thanks
Originally Posted by 1475glenave
(Post 1596365382)
bulb outside the car. Put your left turn signal on and see if one does not blink in the front or back of your car. You could also turn your 4 way flashers on and check the outside bulbs. Check if bulbs are burned out or bad connection. Hope this helps. |
Originally Posted by JETS C3-C4
(Post 1596367774)
There is only one flasher. You probably have a burned out turn signal
Originally Posted by playsdixie
(Post 1596371767)
:iagree:
thanks for your help :thumbs: |
(Post 1596367774)
Corrosion in a bulb socket could also be a culprit. Keep us posted on your results.
how to get to the left front signal bulb
I just got my dads 1985 Corvette (26879 miles) and i need to replace the left front signal bulb. Not much history with this car for me so i have no clue how to get to the bulb in the nose. I see the connectors under the hood but i just dont wanna screw this up. :P
All help is greatly appreciated. theerdman |
(Post 1596376514)
hi playsdixie...i am in bonita springs and grew up in muskegon,mich and spent most of my adult life until retiring in rochester hills mich.
