Brake light will not go out
Hello everybody,
I own a 1989 6spd Z51 Corvette. I just changed the brake booster and the brake lights are on and will not go out. I tried the adjustment procedure in the manual and the one listed on the forum. The lights stayed on. Then I had my daughter look at the lights to see if they went off when I depressed the switch. Even with the switch fully depressed the lights stayed on. Does any body have any suggestions as to what is wrong. Oh and on the back of the switch is what looks like two male ends that should have a plug on them. Looking under my dash I cannot see anything that looks like it should plug on the back of the brake light switch. Thank you for your help. Joe |
Originally Posted by jseremba
(Post 1596369776)
Hello everybody,
I own a 1989 6spd Z51 Corvette. I just changed the brake booster and the brake lights are on and will not go out. I tried the adjustment procedure in the manual and the one listed on the forum. The lights stayed on. Then I had my daughter look at the lights to see if they went off when I depressed the switch. Even with the switch fully depressed the lights stayed on. Does any body have any suggestions as to what is wrong. Oh and on the back of the switch is what looks like two male ends that should have a plug on them. Looking under my dash I cannot see anything that looks like it should plug on the back of the brake light switch. Thank you for your help. Joe If the lights won't go out then it would seem that there's a loose switch up in the dash wires somewhere that you don't have in the brake pedal bracket. Follow the WHITE wire to maybe the hanging switch. With an M6 there's maybe a total of 3 switches up in under there. |
1 Attachment(s)
Originally Posted by WVZR-1
(Post 1596371480)
Changed my mind after a second read.
1 Attachment(s)
Follow the WHITE wire from C104 (large turn signal connector) and see if you don't come across this red connector. Blue is correct for cruise I believe and the LT BLUE & GREY/WHT wires match diagram in FSM for an M6.
Attachment 48244550 |
(Post 1596372083)
Follow the WHITE wire from C104 (large turn signal connector) and see if you don't come across this red connector. Blue is correct for cruise I believe.
Attachment 48244549 Attachment 48244550 This car is a manual. Interesting thing to me is that this problem never happened before. I have had the car for over one year. I change the brake booster and know I have a brake light problem. This guy had an Alpine 8040 security device on the car. I just unplugged it and know this. The switch never had a connector on it. Could this be an open ground. Thank you |
The back of the brake switch does not have prongs. It is a flat piece of brass or copper
1 Attachment(s)
(Post 1596372168)
This car is a manual. Blue connector with LT BLUE & GREY/WHT should be at the clutch pedal. SLS at brake pedal should be LT BLUE & WHITE/no stripe. Here's I believe a correct connector for an '89 M6 from this thread. Maybe this is what you're looking for. Attachment 48244584 https://www.corvetteforum.com/forums...capacitor.html |
(Post 1596372250)
I realized the car was an M6 - you mentioned that in your original post.
Blue connector with LT BLUE & GREY/WHT should be at the clutch pedal. SLS at brake pedal should be LT BLUE & WHITE/no stripe. Here's I believe a correct connector for an '89 M6 from this thread. Maybe this is what you're looking for. Attachment 48244584 https://www.corvetteforum.com/forums...capacitor.html Two things 1) I depressed the Cruise switch the one with the blue and white wires and the lights went out. 2) The person that wired the Alpine made a BUNDLE of wires in that bundle is what looks like the resistor you have pictured. I am betting that the connector is also in the bundle. Thank you for your help. All of you |
