96 Door Panel Install Question
Hey guys I’m restoring my 96 GS and at the stage of reinstalling the door panels back on. There must be a proper way to install these! The top won’t stay in properly and keeps popping out! I’m trying to line it up properly still not fitting correctly. I put new window weatherstripping in and everything went smooth till now.
Originally Posted by ehteam81
(Post 1596372575)
I never got mine to feel tight or sit firmly from front to back of the door, and installed an L bracket on the top of the door(there's a bolt already there) that extends higher than the fiberglass tabs. It's not permanent and makes the door panel fit much better. Best of luck! |
Are your door panels in good shape, or are the plastic webs in back all cracked? The (poor) design relies on the panel's stiffness in bending to stay hooked in at the top. But the webs have a stress riser angle where they have to clear some bracing, and the webs usually crack at those angles. Once the webs are cracked, the panel is no longer stiff enough to stay hooked in. There are some threads here where people show how to make some reinforcing webs out of metal and either bond on with JB weld and/or rivet or bolt them in. That fixes things pretty permanently. I have had to do that on my passenger door, and the driver door is on its way to needing it.
Yes, I removed the panels on my 95 thinking I could improve the fit. No such luck. Sloppy and misaligned is as good as it gets. About the same as my 73. That's progress.
Yeah, it's fair to say that interiors of C4s was not a shining example of "that great GM feeling."
