Ask Tadge Poll: Ending 1/21/18
Vote for which of these 4 you'd like to have Tadge answer. The winner will be submitted 1/21/18.
The questions are posted in the replies below, with links to their respective threads. |
C7 ZR1: Brakes
The original question is here.
jvp asked: There's been a lot of interesting information available online since your introduction of the new C7 ZR1. One intriguing bit that caught my attention is the new brakes for the ZR1. Could you explain how they differ from what's available on today's Z07-equipped car? Is the brake cooling also improved over the Z07-equipped car? |
Engine Cavity and Wheel Cavity Air Management
skank asked: I've read and observed with great interest the air management advancements of the new ZR1. Could you explain the air flow paths through the new front fascia and how they are designed and engineered to move air through those internal locations. Knowing that you have already developed brake ducts to direct air to the brake discs, would directional(asymmetrical) fan style wheels help in the air flow path? I also noticed that the new ZR1 wheels are asymmetrical and therefore look different from driver side to passenger side. Would four location specific wheels be required to optimize the aero through the wheel cavity area or is it not worth the extra cost to the ZR1 budget? |
2017 Z06s and 91 Octane
jgzo6 asked: I have a 17 z06 and live in las vegas. I use chevron and the highest octane I can find is 91at any brand name gas. The local chev dealer told me 91 is fine I have read that the 17 z06 is tuned different than a 15or16 and that's why the owners states 93. I have called GM and was told it will have a slight impact on performance. What I am concerned about is the effect on engine life and no one has answered that question for me .. My z06 is driven on the street only and used for long trips Engine longevity is important to me. |
C7 ZR1 Fuel System Specs
FYREANT asked: Now that the ZR1 details have been announced, we know that it will have a port injection fuel system on top of the DI fuel system for supplemental fueling needs. Many of us are curious as to the details and specs regarding the components of this new fuel system. I believe its been said that it will use the Z06 high pressure DI fuel pump as well as the Z06 DI injectors. For the in-tank low pressure fuel delivery pump and lines, has this been improved to provided a higher flow rate and if so approximately how much more flow does it provide? Also, can any information be released about about the port-injection injector specifications? |
