1974 From Carb to Finally Sniper EFI
After waiting over a half year due to back order, I just started my Sniper EFI conversion last week on my ZZ5. Will be using a Tanks inc.tank with in tank fuel pump regulated close to the tank with a filter regulator and feeding it with the 3/8s fuel line. so far so good as far as the installation goes. Its been fun. Hope it stays that way all the way through with a successful completion and start up. I'd like to thank forum member Dembo for posting pictures of his set up a while back which got me a good start. Stay tuned for more pictures any feedback is welcomed!!....
https://cimg6.ibsrv.net/gimg/www.cor...7a2c0f092f.jpg https://cimg4.ibsrv.net/gimg/www.cor...58d55a32e9.jpg https://cimg5.ibsrv.net/gimg/www.cor...cf1951a102.jpg https://cimg7.ibsrv.net/gimg/www.cor...b4a9dffaf6.jpg https://cimg8.ibsrv.net/gimg/www.cor...58f20a5d87.jpg https://cimg0.ibsrv.net/gimg/www.cor...0fcb2d7f23.jpg https://cimg1.ibsrv.net/gimg/www.cor...0a91c389b6.jpg https://cimg2.ibsrv.net/gimg/www.cor...b9981507ab.jpg https://cimg3.ibsrv.net/gimg/www.cor...5913f1a453.jpg https://cimg4.ibsrv.net/gimg/www.cor...6ac7158f48.jpg https://cimg4.ibsrv.net/gimg/www.cor...4c06bbf36f.jpg https://cimg8.ibsrv.net/gimg/www.cor...4ade69ce7c.jpg |
Very nice. Let us know how starting, idle, driveability, performance and mileage are affected from the change.
:thumbs: |
Is that the fuel filter in front of the tank?
how deep are you in
just a round about number
Does a '74 have a vented fuel cap? If not how are you going about venting the tank?
I want to do this soooooo bad. Please let us know how you like the Sniper because I'll eventually do this and I'm reading everything I can on the Sniper and FiTech systems. |
Mid 71 they went from a vented tank cap to a non-vented tank cap. The pre- mid 71's vented via the gas cap. The mid 71 and up vent through the charcoal canister.
74 - non vented gas cap. Non vented tank caps had a vapor liquid separator on the left side of the tank - that hooked to a vent fitting / line on the tank and the steel line to the Charcoal Canister. |
Originally Posted by theandies
(Post 1596445831)
Once these cars went to the fuel vapor recovery tank system, THAT became the vent for the fuel tank. Fuel cap was then non-vented.
My Sniper system just arrived yesterday, maybe my install might turn out as nice as redcruz1120. T
Originally Posted by F4Gary
(Post 1596445056)
Originally Posted by george2066
(Post 1596445223)
(Post 1596445831)
Originally Posted by terrys6t8roadster
(Post 1596447358)
Nice.
Please keep the results coming and thanks for taking the time to answer every ones questions. |
:thumbs:. Hopefully I'll be able to get it started this Sunday. It's my off day
(Post 1596449541)
Nice.
I put a EFI system (MSD atomic) on my 69 GTO and I love it. It runs so smooth and gives instant response when you press the gas. I can easily light them up at 40mph if I'm not careful, haha! Just be aware that if it's like the MSD system, it takes a few starts for it to learn what the car needs and doesn't need.
Originally Posted by redcruz1120
(Post 1596449274)
Yes it is. A filter/ Regulator.
Originally Posted by flyeri
(Post 1596453539)
Why are you using a regulator there? I thought the Sniper had a regulator in the throttle body eliminating the need for one. Am I mistaken? I'm planning the same upgrade, tank and all so I really appreciate your post and pictures.
(Post 1596453976)
Yes it does have a built in regulator but my return line would be too small and I want to minimize the use of hose all the way from engine to the tank.. this way it spills back to tank from about a foot away via Steel tubing.
(Post 1596454211)
I like your idea of minimizing the hosing. What part number for the regulator and where did you get it? T
from Tanks inc. part #LS9904. They also offer it in a kit form which includes the AN fitting connections. https://cimg5.ibsrv.net/gimg/www.cor...396ce1a4ff.jpg |
