Originally Posted by rcread
(Post 1596536169)
I got a Sniper EFI for Christmas, for my '72 LeMans and am debating whether to go with the Tanks fuel tank and pump or just go with Holley's tank and pump. What made you pick Tanks?
Originally Posted by redcruz1120
(Post 1596536215)
Holley gets their tanks from Tanks inc!.. Also Holley techs told me that the GP2 pump I got from tanks inc was great for my Application GM ZZ5
Originally Posted by 73ls1
(Post 1596518135)
I bought the tank to use with my LS1. Old tank was leaking. Where did you mount your vent valve? Looks great,thanks Charlie.
https://cimg2.ibsrv.net/gimg/www.cor...129eb905d0.jpg https://cimg2.ibsrv.net/gimg/www.cor...638137e42d.jpg |
Thanks Charlie
Got updated software
Got my new SD card. Will update post tonight!
https://cimg5.ibsrv.net/gimg/www.cor...e5c9397fbe.jpg |
Fired Right Up!
nice!!
I put a efi on my 71 and can not believe the difference like night and day and the price has come down a lot
Does anyone have a ballpark for how much it would cost for a shop to install one of these would be? It's probably out of my league installation wise, I can fix all the vacuum tubes and electrical things, but this is probably too much.
I'm trying to decide whether to install this or buy a new engine with EFI. My current engine is a non-numbers matching base 350, so this could be a big upgrade to it...but at the same time, it might be worth it just to swap the whole thing depending on what the price difference would be. |
Originally Posted by taylor34
(Post 1596554587)
(Post 1596551907)
Originally Posted by jim2527
(Post 1596555306)
I think you'll be OK.
If you can do basic electrical you should be able to do this
Originally Posted by Johnnypegs
(Post 1596556036)
What serpentine kit do you have? And the AC compressor is a Sanden?
The serpentine system is that of GM. It came with the engine and the Compressor it is a Sanden. It also came with my Vintage Air set up. The compressor here is the one that came with engine too but was eventually removed to make room for the Sanden. https://cimg0.ibsrv.net/gimg/www.cor...187c97ba2d.jpg |
(Post 1596557055)
(Post 1596554587)
(Post 1596557133)
I have The same set up. And I just ordered the vintage air kit, but I didnt Have them include the compressor because I wanted To use the original bracket. Does the Sanden compressor fit into the bracketing or did you have to use the supplied brackets by vintage?
Here's a better picture of how the Brackets look like with the Sanden compressor https://cimg5.ibsrv.net/gimg/www.cor...0f4d565e87.jpg |
(Post 1596554587)
(Post 1596557212)
my neighbor was a Vintage air dealer and he ordered the Sanden compressor mount to adapt to the serpentine bracket. it looks like a half moon , 2 pieces and they fit like a glove. and no the sanden compressor did not fit in the original bracket
Originally Posted by Black04Vert
(Post 1596557465)
Keep in mind that an EFI unit only upgrades your horsepower/torque by plus or minus 5 HP or so over a tuned carb. However, idle, starting, cold engine operation, low speed operation, and fuel efficiency are normally considerably better with EFI.
