Piston pressure numbers help
Hi guys,
I did a engine pressure test and this is the finding. https://ibb.co/cLRutb Do you guys think this is acceptable. The dealership said it is OK ? Thanks Guys |
The two in the 150s are weak.
Originally Posted by aalqaedi
(Post 1596440389)
Hi guys,
Hi Billy,
What do you recommend. Piston ring change? Aftermarket piston . I have no clue what to do :) |
That's a pretty big variance between top and low pressures. Outside of acceptable range I would think.
You need to disassemble unfortunately. The heads have to be pulled and the pan dropped and the pistons pulled. Could be ring failure, ringland failure, or something else entirely..
I would say that the ring lands are broken. Wiseco makes a drop in piston set for the LT1. I pull the motor to do this job.
(Post 1596441666)
Hi Billy,
I did find the piston
Wiseco 6.2L LT1 -.6cc Stock-Replacement Drop-In Pistons for Stock Connecting Rods, No Balancing Required. It this the piston |
(Post 1596450084)
