The Race Engine Shop Short Or Long Block Sale
Fully Forged GM Gen III or IV LS Series Short Block. Pictures are representations of some of engines we have built. Price includes a used structurally verified and Clean Iron 4.8/ 5.3 block ( approximately 326 - 383 CID depending on parts selection). Other blocks and components are available and listed below. This is not everything we offer. We can do Just about anything you want to do. Parts List •Durabond Cam Bearings •ARP Pro Series 8740 Material Head Stud Kit •ARP Pro Series 8740 Material Main Stud Kit •K1 Technologies 6.125" Forged Connecting Rods With ARP2000 Bolts or Callies Compstar Connecting Rods •K1 Technologies 3.622" or 4.000" Stroke Crank with 24 or 58X Reluctor •Wiseco (2618 Material ) Forged Pistons and Tool Steel Wrist Pins with A Ductile Iron Nitrided Steel Top and Napier Second Ring Pack. •New King XP Series Tri Metal Main and Rod Bearings Machine and Assembly Labor Plus Extras •Block and Crack Checking on all new and used Cores •Block Pre Machine Cleaning Deburring •Prime and Painting with VHT Engine Enamel, Red, Black or Orange (Other colors Available at Cost of Paint) •Align Hone the main housing bores •Cylinder Boring (If Necessary) •Torque Plate Cylinder Hone with Plateau Finish •Block Decking and Quench Distance Setting •piston and Rod Pin Fitting and Big End Sizing (If Necessary) •Crankshaft Blueprinting (Checking For Straightness and Correcting if Necessary) •Crank Balancing (heavy metal not included) •Block and Component Final Cleaning And Final Deburring •BluePrinting of Block and Components •Block Plug Kit Installation •Final Assembly. Price Includes all associated Labor with block and hard parts purchased through The Race Engine Shop. Customers are welcome to send their own parts but additional charges MAY BE assessed on a cast by case basis. The following includes but are not limited to examples of customer provided parts extra charges. Pin Fitting, Rod Resizing, Crankshaft checking, Crankshaft Balancing, or any correction to components deemed necessary by the Race Engine Shop for a suitable engine. Contrary to popular belief, all shops ultimately charge for blueprinting. Some will lower their price by eliminating steps (such as blueprinting) as it saves time. Time is money! One of the most common steps eliminated is blueprinting itself. A vast majority of blueprinting is to verify tolerances of components that the engine builder does not produce. We would rather keep you out and running then having problems because we wanted to save a bit of time and pocket a few extra bucks. “We are not interested in selling a steak and delivering a hamburger if that makes sense” Some things to pay attention to and components to NOT get caught with when shopping for a high performance engine.
•Estimated Completion Time approximately 30 days depending on any additional parts selected and their availability. •How Much Power Will The Engine Support that’s largely dependent on the engine management calibration and parts selection and induction type among most things. On an engine like the one above; it should be able to support 1200 HP. Yes I understand there are people out there with bone stock bottom end 5.3L engines making astronomical Power. All it tells me is that they have got away with it to this point. Those are ticking time bombs and most of the people who do that kind of stuff usually understand that. Building a high performance engine isn’t about getting away with Something. Rest assured when you make big power, the BS is coming. Get your self an engine that will take the BS head on. The Total For The Above Engine as Listed is $4,380 plus shipping. I like to use fastenal’s 3PL Program for shipping. The cost of materials and time for me to build a crate is $140 (not included in price) ————————————————————— All the following prices are for parts upgrades and would be added to the total for the above engine <—— pay attention to this. Seriously! Oil Pump Camshaft and Accessories Melling oil Pump part number 10296 +156 Camshaft of your choice from BTR (Comp cams Core) or a custom grind +365 Lifter trays and bolts +35 OEM Lifters +100 Pushrods +110 Engine Block Options (Used Cores Available for most blocks at a significantly reduced price market value dictated) New Iron 4.8/5.3 Block +300 New Iron 6.0 Block (Gen 4) +1,126 (Gen 3 Available reconditioned Core only) +600 Aluminum 5.3 Block used Core only +200 New Aluminum L92 / LS3 Block +1695 New Aluminum 6.0 LS2 Block +1,264 New Aluminum LS7 +3,177 New Rotocast Aluminum LS9 Block +3,835 New GMPP LSx Standard Deck Block +2,730 *New Dart SHP Pro Iron Block. +2,407 (requires different head Stud Kit) and requires Block parts kit. (Pro Block Not Available yet but Standard SHP is Available now) Adjustable Timing set with heavy duty chain +130 Piston & Ring Options Custom High Boost or Nitrous Piston Kit includes proprietary sized AP Stainless Ring Pack specifically for those running high boost or high amounts of nitrous. +700 Crankshaft Options Callies Ultra Billet 4330VM Timken Steel Crankshaft Center Counter Weight Crankshaft (Includes Center Counter Weight Block Clearance) with engine Build) Stoke 3.500” and under +2,068 Callies Ultra Billet 4330VM Timken Steel Crankshaft Center Counter Weight Crankshaft (Includes Center Counter Weight Block Clearance) with engine Build) Stroke Over 3.500” +3,131 Callies Dragon Slayer Crankshaft +934 3.625” - 4.125” Stroke in incremental stroke sizes. Dart 4340 Billet Center Counter Weight Crankshaft 4.000” or 3.600” Stroke (Includes Center Counter Weight Block Clearance) with engine Build) Available in long snout for factory dry sump application. +532 Callies Compstar Crankshaft 3.625” or 3.622” Stroke +203 Connecting Rods Callies Compstar H-Beam Rods with ARP 2,000 Bolts +360 Callies Ultra H Beam Rods +600 Callies Ultra Billet I Beam Rods 4330VM Timken Steel +1,169 Wiseco Boostline Rods +619 Fastener Options Callies MP 3.5 Rod Bolt Upgrade (Callies answer to CA 625+ Material Rod Bolts) really good stuff. Needs to be ordered prior to ordering Rods. +440 ARP CA625+ Head Stud Kit (Non 6 Bolt Heads) +455 ARP CA625+ Head Stud Kit (Non 6 Bolt Heads 1997 -2003 multi Length) +551 ARP CA625+ Head Stud Kit for 6 Bolt Heads +601 ARP CA625+ Main Stud Kit. +411 Dart SHP Block pre Pro Series SHP Block Main Studs (Only 8740 Material Available) +136 ARP2000 Head Stud Kit For (2004 and Newer + $154 https://cimg5.ibsrv.net/gimg/www.cor...e90648fd2c.jpg https://cimg6.ibsrv.net/gimg/www.cor...12048ca64f.jpg https://cimg2.ibsrv.net/gimg/www.cor...083cc5bb75.jpg https://cimg3.ibsrv.net/gimg/www.cor...062bd64a17.jpg https://cimg4.ibsrv.net/gimg/www.cor...401754d882.jpg https://cimg7.ibsrv.net/gimg/www.cor...71c06ece62.jpg https://cimg8.ibsrv.net/gimg/www.cor...a360d039e7.jpg https://cimg9.ibsrv.net/gimg/www.cor...ead7db3ef8.jpg https://cimg0.ibsrv.net/gimg/www.cor...beaf5afc0c.jpg https://cimg1.ibsrv.net/gimg/www.cor...dad4ea68b1.jpg https://cimg2.ibsrv.net/gimg/www.cor...da36607a60.jpg https://cimg3.ibsrv.net/gimg/www.cor...842c3e6f7b.jpg https://cimg4.ibsrv.net/gimg/www.cor...92a8c7ae81.jpg https://cimg5.ibsrv.net/gimg/www.cor...525c420d20.jpg https://cimg6.ibsrv.net/gimg/www.cor...b701fcafeb.jpg https://cimg9.ibsrv.net/gimg/www.cor...7e48b35df5.jpg https://cimg2.ibsrv.net/gimg/www.cor...eb46805465.jpg https://cimg3.ibsrv.net/gimg/www.cor...1d0d0e314f.jpg https://cimg4.ibsrv.net/gimg/www.cor...915680b1e0.jpg https://cimg5.ibsrv.net/gimg/www.cor...5da41f13ef.jpg https://cimg6.ibsrv.net/gimg/www.cor...ce00bd380e.jpg https://cimg7.ibsrv.net/gimg/www.cor...30f69f1c0f.jpg https://cimg8.ibsrv.net/gimg/www.cor...05fc758d63.jpg https://cimg9.ibsrv.net/gimg/www.cor...67d6ff0503.jpg https://cimg0.ibsrv.net/gimg/www.cor...5c3e8d0b7e.jpg https://cimg1.ibsrv.net/gimg/www.cor...341b64db3e.jpg https://cimg2.ibsrv.net/gimg/www.cor...da660fcc4c.jpg https://cimg3.ibsrv.net/gimg/www.cor...fb12d25bd1.jpg https://cimg4.ibsrv.net/gimg/www.cor...0406e15ed7.jpg https://cimg5.ibsrv.net/gimg/www.cor...5e05df8044.jpg https://cimg6.ibsrv.net/gimg/www.cor...e6e1107bdf.jpg https://cimg7.ibsrv.net/gimg/www.cor...807f85bb80.jpg https://cimg8.ibsrv.net/gimg/www.cor...5025a0624e.jpg https://cimg9.ibsrv.net/gimg/www.cor...d637e01332.jpg https://cimg0.ibsrv.net/gimg/www.cor...c210904297.jpg https://cimg1.ibsrv.net/gimg/www.cor...f11b39fe7e.jpg https://cimg2.ibsrv.net/gimg/www.cor...c472ecc735.jpg |
Definetly going to bookmark this thread for the future build. Let's hope this 3k mile shortblock stays together with a nice n/a setup at 7k rpm. If not I know where to go.
I loves me some engine porn!
Folks, while you may not have heard of this company before, I can tell you that I've known the owner for 8 years now and he's one of my favorite people on this planet. He's incredibly passionate about his work and will let absolutely nothing get in the way of executing perfect work. He enjoys taking the time to visit with potential customers to share ideas and reasons for why things should be the way he prefers to do things. While you might find cheaper engines out there, you'll have a difficult time finding someone that will produce such a quality product at the prices he commands. He is thoughtful and deliberate with each and every move he makes around an engine. It's an absolute pleasure watching him build engines. Give him a try, you won't regret it! :flag: Bret |
Here’s a LSx Based 427 CID Engine I built for Greg’s Magnacharged C6 Z06. It also has some Spray just because. It made over 1,000 Wheel HP. The Car was Built and Tuned by Corvette Forum Supporting Vendor BlownBlueZ06@RKTPerformance |
Lots of options available. |
Current Inventory of blocks ready to machine and assemble
(2) LS2 aluminum blocks (2.) Gen 3 4.8 / 5.3 Iron Blocks (1) Gen 3 6.0L Iron Block (1) Gen 3 6.0L Iron Block will be .030 over. (1) Gen 4 4.8/5.3 Iron Block (1) Gen 4 4.8 / 5.3 Aluminum Block (1) Gen 4 4.8 / 5.3 Darton dry Sleeved Aluminum Block 4.125” Bore this one is $1,100 for the block. If you act now I will give you 15% off the listed price for any of the block core prices. |
Bumping this for a reminder for me
I'm in H-town and never heard of you, too bad, I needed a engine a couple of years ago and would have love to give you some business. I've had two engines installed in two years for my vette and my '55 Ford truck, I'll keep you in mine for the future. L8R ZFLASH
Originally Posted by ZFLASH
(Post 1596772143)
most definitely! Hit us up when you’re ready! |
