Bee Jay’s LS7 Conversion
Hi guys. I blew the motor in my 2013 Corvette 427 Convertible. Luckily, it was under warranty and I got a new motor. I got the core motor, so I have a 427 LS7 motor with a bad crank and two bad titanium rods. The motor only had 7K miles on it when I spun the rod bearings. So,.....resistance was futile, but after 20 years of resistance, it looks like I'm doing an LS conversion. 100 more horsepower, and 100 lbs less weight. Stay tuned. Any advice?
Bee Jay PS I miss you guys. They are not as friendly on the C6 forum. Maybe it's me and my cold personality.:rofl: https://cimg6.ibsrv.net/gimg/www.cor...df513f791e.jpg https://cimg7.ibsrv.net/gimg/www.cor...128ee35160.jpg |
:thumbs: Finally saw the light (pun intended)
convert it to wet sump.
Originally Posted by 3X2
(Post 1596526605)
Have the heads done so don't drop a valve.
Great story and good luck with the swap.
To me, there is just something magical about the designation "427". It is just an iconic nomenclature that truly belongs in a C3! Please keep us posted with your progress. If I ever finish with my driver restomod, my next project will be a beast of a car and was planning on starting with the LS7 as the base. |
(Post 1596526605)
:iagree:
Originally Posted by PainfullySlow
(Post 1596528549)
To me, there is just something magical about the designation "427". It is just an iconic nomenclature that truly belongs in a C3! Please keep us posted with your progress. If I ever finish with my driver restomod, my next project will be a beast of a car and was planning on starting with the LS7 as the base. I had a 427 in my 68 C3, and hope to have one in my current C3 one day too,, ( ls version now,,) I want - 427, 427, 427, ,,,three times on each side of the hood bulge,,:woohoo::thumbs: |
Originally Posted by Bee Jay
(Post 1596528653)
Why convert to wet sump? |
Originally Posted by 69427
(Post 1596529762)
I'm not answering for 3X2, but he did get me curious about where one would package a dry sump reservoir/tank in a C3.
(Post 1596529762)
OP: out of curiosity, how the hell did you convince the dealer to let you keep the old engine? Unless things have changed in the 25 years since I worked for GM Parts, they always wanted the warranty items back.
(Post 1596529762)
or possibly where your vacuum reservoir used to be.
(Post 1596528653)
1 Attachment(s)
Originally Posted by 79 Bullet
(Post 1596530767)
possibly in the back? somewhere near the tire carrier area. Better weight distribution and cleaner install. Especially since the oil lines are already on the bottom of the motor? Keep it dry sump!
(Post 1596532676)
Won't fit. The last one I did, it was mounted behind the passenger seat bulkhead. Battery was on the driver side. As you can see, this Corvette has a fuel cell.
nice car you have posted there:cheers: |
(Post 1596532648)
The lines for the tank exit the oil pan on the right side. No place to install a proper tank and vent can. Honestly, I don't think a stock or semi stock suspensioned C3 on street tires can generate the cornering that would require a dry sump engine.
https://cimg7.ibsrv.net/gimg/www.cor...2303b643b0.jpg https://cimg6.ibsrv.net/gimg/www.cor...bcfae62f1a.jpg https://cimg9.ibsrv.net/gimg/www.cor...905ef739c7.jpg |
Looks good. Will it fit an a/c car? What are you using for a vent can? Got more pictures?
Hi guys. I'm going to be lazy and just cut and paste what I just posted on the C6 Z06 forum.
Bee Jay Thanks for all of the positive comments guys. I started the tear down and got the heads, oil pan, and oil pump off. Like I said, I'm new to this LS stuff. I've been very impressed with my 200,000 mile GMC 6.0 liter truck. But losing this LS7 in less than a couple of weeks had me doubting. I've done several small blocks, I built my 79 L-82 into a 383 LT4 Hot Cam killer, and I've done a 454 big block. But this is my first LS engine build. You can see the 5 & 6 rod caps are discolored, and you can see what the spinning of the rod bearings did to the crank. Can the crank be repaired? Can the two discolored rods be saved. Stupid Question: How do you rotate the crank? https://cimg4.ibsrv.net/gimg/www.cor...116953b97.jpeg https://cimg5.ibsrv.net/gimg/www.cor...1921f6994.jpeg https://cimg6.ibsrv.net/gimg/www.cor...d3f3b2498.jpeg https://cimg7.ibsrv.net/gimg/www.cor...614b1fdd3.jpeg https://cimg9.ibsrv.net/gimg/www.cor...be214725f.jpeg https://cimg0.ibsrv.net/gimg/www.cor...df6725a29.jpeg [/left] |
