1992 corvette SYS and security light flashing
so iv pretty Much dialed down all my other issues and this is my last bit. My SYS and security light are flashing. My trip/ gas buttons don’t work either, is there a correlation with these? Iv looked up other forums but most of them say SYS and no start condition. My car runs pretty much perfect (for 140,000 miles id say). Since I can’t use the gage buttons I can’t get rid of the change oil light either. Where should I begin? Any help would be great thank you |
The security light should flash when the door is opened and the key is not in the ignition or engine running.
The SYS light many times indicates the battery is weak and may need to be replaced. However the SYS light may also indicate a code in module 1 of the CCM. You might try to pull the codes and just see what comes up. As a very very long shot, disconnect the battery for a minute and see if there are any changes. Pull the codes first because all codes will be cleared when battery is disconnected. |
Originally Posted by pcolt94
(Post 1596539342)
Originally Posted by Brenden Schaeffer
(Post 1596539481)
i raplaced the battery and alternator less then a month ago, I pulled the codes and am getting C13 and H13 in module 1. Isn’t that for the left 02 sensor? I just replaced them both Do you have the FSM? I posted CCM diagnostics in a .pdf to a post last week. It's the complete CCM diagnostics and CCM section from the FSM. Here's the thread - I asked a user to 'proof read' - I don't see where he's ever responded! https://www.corvetteforum.com/forums...post1596491081 |
Originally Posted by WVZR-1
(Post 1596539565)
13 is a DIC switch shorted to B+ OR 'open'
Do you have the FSM? I posted CCM diagnostics in a .pdf to a post last week. It's the complete CCM diagnostics and CCM section from the FSM. Here's the thread - I asked a user to 'proof read' - I don't see where he's ever responded! https://www.corvetteforum.com/forums...post1596491081 hmm weight I took a look at that what exaclty does that mean though? |
(Post 1596539565)
B+ signifies +12 volts from the battery. Open means it is not connected.
Judging from your original post and the C13/H13 codes it hints maybe bad DIC, poor connection @ DIC or maybe even a CCM issue. SYS & SECURITY maybe throws a bit of a curve to the diagnostics though.
Have you ever been into the dash for any issue at all? Is the radio OE or after-market? Maybe not relevant to your issue but it might explain someone being in the dash. It seems maybe ODD that with the DIC mostly inoperative that you could actually get into the CCM diagnostics. You used a procedure similar to those in the file I posted? |
(Post 1596540494)
(Post 1596541251)
I took off the dash peice that covers the radio and DIC just to clean stuff off, the previous owner put in a new radio. If you had the DIC in your hand, then when you replaced it you didn't get the harness connector secured. Is this a recent problem or it's been there since you bought? I'd think the first check would be the connector @ the DIC. I've replaced the DIC, the printed circuit on a couple but I've never removed the actual 'switch pack' to see how practical it might be to just maybe check/replace the resistors used. Dependent upon 'talent' maybe that's a viable option. |
Depending on how the new radio was installed it can cause a SYS light. Does your car have the C68 automatic temperature control?
(Post 1596541290)
I've replaced the DIC, the printed circuit on a couple but I've never removed the actual 'switch pack' to see how practical it might be to just maybe check/replace the resistors used. Dependent upon 'talent' maybe that's a viable option. so just check the connector in the back? It has been his way since I got it |
(Post 1596541964)
so just check the connector in the back? It has been his way since I got it Using this link you check the connector 'above' the AH and also to the left of the AH. Image #5 I believe in this eBay offering. https://www.ebay.com/itm/Drivers-Inf...!US!-1&vxp=mtr |
Originally Posted by ihatebarkingdogs
(Post 1596542952)
He's getting a SYS light because he has a C13 code.
The codes associated with a radio replacement are 72 and 74 (I think. Something like that. Up in the 7x's. He doesn't have those.) I understand why the C13 - if he has enough control over the DIC to clear CCM codes fine but it might not necessarily make the issue go away. |
(Post 1596538675)
(Post 1596577222)
No you didn't. JIM LENTZ DID!
Why you quoting ME???? I quoted Jim Lentz, not YOU. Read!! whoa whoa whoa calm down lol. Iv been on vacation but I got into the dash today and the connector on the back was out a little little but and a little dirt cleaned it up and now the DIC works fine so thanks for the all the help. Now any one know how to take apart the steering column to get to the blinker and cruise control lever it’s loose and only left had (down) works but pulling it back, up, forward, it’s all super loose and not even connected |
