What Autocross class sould I be in?
I recently purchased a 2001 coupe that has some track mods from the original owner. Can you help me class my car for local events. I think it should be ST(U or P) depending on tires. I'm looking at running Z06 18x10.5 front and rear with RE71R 285/30R18.
Other mods include Simpson 5 point harneses on driver's and passenger side (factory belts still usable) AZ Speed and Marine harness bar and Brey Kraus clip mount for outboard lap belt Pfadt Camber plates, -1.8 deg front and -1.5 deg rear camber Hotchkis front and rear sway bars with adjustable heim joint end links Updated tie rod ends front and rear Magnaflow muffler and X-pipe, it was a CA car and passed smog so I believe the cats are functional The motor does some sort of tune, but again it meets CA Smog Callaway Honker cold air intake, Granatelli MAF, Callaway Billet throttle body, CA smog legal 160 deg thermostat and throttle body coolant bypass Front brake ducts, stainless steel brake lines, StopTech DOT 4 hi temp brake fluid Kirban billet short throw shifter Underguards, side sill underbody protection rails with jacking pads Skid plates to protect radiator mount under nose of car CCA aluminum pedals great for heel and toe shifting Oil catch can inline with PCV valve Pfadt nose mounted oil cooler Thanks Don |
Definitely not STP, maybe STU but the throttle body may kick you out. CAM-S for sure.
ST rules are here: https://dk1xgl0d43mu1.cloudfront.net...pdf?1484692402 |
Yup looks like cam-s to me unless you change the throttle body back to stock.
The MAF and throttle body would have to go back to stock to run in STU, technically. For locals though, I'd just check with the other STU competitors, and if they're OK with it, run STU. If you're new to autocross, it's not going to matter what class you're in, so run in the most appropriate one (STU).
I hope the OP doesn't mind me asking a similar question here. :)
My 2002 C5 Z06 has an engine oil cooler, CAI, and aftermarket engine mounts and shifter. These should put me in the Street Touring category but I cannot find where in ST the C5Z falls. Is there no C5Z in ST? |
Correct no z06 in ST, just the non Z06 in STU.
Originally Posted by xtremeyolks
(Post 1596761051)
Originally Posted by The_Backmarker
(Post 1596762761)
Dang! Sucks to be me. I guess it's Time Only then, LOL
(Post 1596761051)
Also, keep in mind that STU has a max tire width of 285 I believe. CAM-S is pretty much the catch all. Nearly unlimited mods. That's what I race in but I was debating on going with slicks next season so I think I'd be SSR. |
Originally Posted by Tomswheels
(Post 1596764787)
CAM-S is perfect for you....
Originally Posted by Acid666
(Post 1596766022)
Correct. I was looking at where I could put my C5Z with a few mods and 200 tread rated tires and I couldn't go into STU.
(Post 1596766122)
Yeah, I guess. I'll be very under-prepared there.
Originally Posted by mattastick
(Post 1596766811)
The C5Z that's won Nationals the last couple of years has been a very basic build. You don't need a lot to win in CAM, just a good driver.
Originally Posted by eric1855
(Post 1596767105)
(Post 1596766811)
A good driver goes a long way in autocrossing, and a C5Z is already fairly well prepared from the factory. The rich guys who want to own the fastest possible car haven't really invaded CAM-S yet, but when that happens, a "basic build" will be at a disadvantage. Until that happens, have some fun. |
(Post 1596766122)
What's the difference of being under prepared for there vs running time only? At least in cam you'll have a benchmark to guage yourself against... I've never understood this mentality for competition |
(Post 1596766122)
For the record, that's me, and I beat all the Mustangs and a Nissan 370Z at that event on raw time, and I came in third in my group on PAX adjusted times. It's way more fun to drive a slow car fast than it is to drive a fast car slow.
Originally Posted by chetly
(Post 1596815404)
I've never understood this mentality for competition Valid reasons for "Time Only:"
(Post 1596815404)
I've never understood this mentality for competition Here's a dramatization featuring a CAM car: If you ain't first.... |
If you want a "first place" participation trophy, run EM in a small region where nobody else is running EM.
Nobody wants to be last, but for first year, beginning drivers, there's almost always at least five or six seconds in upgrading the "loose nut on the steering wheel." The way to improve that situation is run as many events as you can with what you have. If there are autocross "beginners/novice schools" at regions within driving distance, those are even better than full out competition events. The great thing about experience is that it transfers and installs fairly easily in any car you get into in the future. The next "performance mod" (worth it for late first year/second year beginners) is a dedicated set of good (hopefully class legal) "autocross tires." Don (the OP) is apparently considering that upgrade with the RE-71R's (great tires, BTW). |
C'mon Eric, aren't you basically basic? Its kinda like saying you're basically stock.
