1985 4+3 OD Sluggish
For a while now, my OD has taken a moment to engage. I chalked this up to the OD not wanting to engage while I have my foot down or the RPMs are too low or something. It has started to get more sluggish engaging recently, however.
This morning I really couldn't get it to come on at all. Yes, the car was at temp (180 F) and I was doing about 55 at ~2200 RPM (forget exact RPM but the OD should definitely engage at that point). It is kinda cold here today, ~32 F, which seems to always have a negative effect on the OD performance. Only time I could get it to engage fully was coasting downhill at the above speed/RPM. On level ground, even coasting, it wouldn't engage. The OD light on the dash comes on, so I know the computer THINKS it should be on. Do I just need to add fluid to the unit? I suppose if I'm going to add fluid I should drop the pan first and change the fluid entirely. Anything else I should check? |
Do 85s have kickdown cables for the overdrive? May need to be adjusted possibly as well. Just saying.
Originally Posted by 84 4+3
(Post 1596575576)
Ok did some Googling, looks like the kickdown cable only tells the O/D unit to shut off under full throttle. I don't THINK that's the issue based on the behavior.
Originally Posted by Bfenty
(Post 1596576090)
If you suspect that you are low on fluid I recommend that you check it. It's doing more harm than good if that's the case... |
(Post 1596574479)
This morning I really couldn't get it to come on at all. Yes, the car was at temp (180 F) and I was doing about 55 at ~2200 RPM (forget exact RPM but the OD should definitely engage at that point). It is kinda cold here today, ~32 F, which seems to always have a negative effect on the OD performance. Only time I could get it to engage fully was coasting downhill at the above speed/RPM. On level ground, even coasting, it wouldn't engage. The OD light on the dash comes on, so I know the computer THINKS it should be on. Do I just need to add fluid to the unit? I suppose if I'm going to add fluid I should drop the pan first and change the fluid entirely. Anything else I should check? i forget if u already dropped the pan on this unit? have u checked fluid on it yet? |
Originally Posted by VikingTrad3r
(Post 1596577987)
i forget if u already dropped the pan on this unit? have u checked fluid on it yet? I assume that driving without the OD if it has low fluid will still damage the unit? It is still transferring power even if it’s not engaged, right? |
Reverse still works just fine too-which I’ve read is a good sign for the OD unit being ok. |
brandon i think there are gears still spinning. ut not sure about torque applied into the od unit in gears 1-4. drip that pan and show us what you see!! |
Wow-thanks all for the information. I’m learning a lot about how this OD works. Lucky for me, I DO have a spare OD unit that I know is in great shape. Not sure I want to jump to just swapping it out but I have a backup if need be, or if there’s a part I need to pull. I’m ASSUMING it’s difficult to just swap the unit out? it might be a few weeks before I can drop the trans pan. I’ll park it until then and provide updates when I can. Thank you everyone for the advice! |
(Post 1596580772)
Originally Posted by arbee
(Post 1596581999)
Go to the following link. The video author has several videos including rebuild of this O/D unit.
https://www.youtube.com/watch?v=cS6vA3UR4jM |
one other thing I was thinking-is it possible/easy to add a drain plug to the pan once it's been dropped? I was thinking about doing that to make it easy to drain the fluid, and then just swap the fluid every time I change the oil or something. I know that's more often than necessary but I'd rather overdo it than ruin the OD.
Originally Posted by ihatebarkingdogs
(Post 1596582854)
You would then be overlooking the most important aspect of "changing the fluid". Being able to inspect WHAT is IN the pan. Hopefully nothing of course. But if there is any debris indicative of an impending failure, you want to know about it.
I'm not saying I'd never drop the pan, just thought it might make it easier to swap fluid often. But I'm really not much of a mechanic so I'll take your advice. |
Way too much diagnostic information being thrown at you at this point of your investigation into your problem. Start with the very basic and inexpensive fluid and filter change. Your problem could very easily be only that your O/D fluid level is too low. It happened the same way to mine. I had a small leak and the level dropped too low. You can add some additional fluid, but you might as well just do the required fluid change. With your symptoms so far, I'd go that route.
Originally Posted by FOURSPEEDVETTE
(Post 1596589198)
BS. Too much information! What a ridiculous statement. |
(Post 1596589198)
Also there is NO SUCH THING as too much information! But you're right, I need to start with the basics. those videos were hugely helpful. I have a tendency to get paranoid and assume the worst-that my car is about to go up in a giant fireball or something. |
(Post 1596589925)
Thanks! I'm a little slower to diagnose these days (ask VikingTrader-I used to diagnose and fix something in hours not weeks :)
(Post 1596594529)
Don't be overly concerned with that technical 17 minute video yet or all the technical comments. You don't need to be. A simple fluid change may be all you need. My ridiculous comment of "too much information" while hard for "arbee" to figure out, just mean's that some guys love to dazzle you with brilliance or baffle you with bullsh-t. It's all up to you. You can try the cheapest approach first, or replace the whole transmission at a cost of thousands of dollars. Seems like a no brainer to me.
I appreciate you both-the transmission video is hugely helpful because now I can picture what is going on in there in my head, and it will help me understand what I feel/hear in the future. I love seeing a clear demonstration of what's going on inside my car, and having a good understanding of everything makes it easier to diagnose even the simple stuff.
That said, I also need to start with the basics and remember not to panic. It's probably a simple solution! And if it's not, I will deal with that when it happens. I appreciate the reminder to keep it simple. Love this forum and everyone on it! |
