Originally Posted by FYREANT
(Post 1596740673)
What would you like to hear? I have the drop in VR pistons and currently am sitting around 900 wheel..
Originally Posted by stab1991
(Post 1596740980)
hi Ant, do you have the stock rods still? Pistons are my next step since I’m already pushing it a little past the comfort zone on the stockers. I need to find a shop near me in Jersey to do the install. |
(Post 1596741107)
Yes sir. Stock LT1 rods and crank. :)
VR Pistons with stock rods and stock crank in my LT1... If i was doing it all over again, i would chang rods too... Nothing wrong with just pistons, but if i ever decide to push it even harder it would be there...
Not sure if anyone makes drop in rods and pistons... |
Originally Posted by Osman
(Post 1596741431)
Originally Posted by RelentlessSecurity
(Post 1596741373)
Any idea what the labor for the install was on the pistons?
(Post 1596741431)
Not sure if anyone makes drop in rods and pistons... Ant |
Its about $4000.
(Post 1596741373)
Originally Posted by Billy@MTI
(Post 1596774808)
Its about $4000.
Originally Posted by John Micheal Henry
(Post 1596779191)
Billy, Do you remove the engine to do the install??
can't imagine it being done with the motor in, thats why im waiting to do mine for a couple years then ill really turn the boost up :D
Get ready to pull the front carraige and put your engine in an engine holder! Cant no way do a piston upgrade without taking engine out! Hey if you know a way pist it asap! After you get copyright it...lol |
I have a stage 2 Edelbrock E Force, 9 pounds of boost. Made 520hp on a Mustang dyno(close to 600 on Dynojet). It was rich at wot put, afr in the 10s. on Edelbrocks tune. I was thinking of getting a custom tune for more power and to lean it out to mid 12s at wot. Now I'm thinking of just leaving the Edelbrock tune after reading this thread. Thinking Edelbrocks rich tune would keep the pistons cooler and help avoid this broken piston issue?
Originally Posted by BlueDevilZ51
(Post 1596794339)
AFR in 10s... eeekkkk... that is way way to rich for DI.. BUT Keep the timing out of it and leave it rich and it should last... |
Yes we do. Pretty much the only way to do it right.
(Post 1596779191)
(Post 1596795496)
No thats the R/R labor, honing block and reassembly. You are very welcome.
(Post 1596808007)
Billy, Does that price include all parts and labor? Thanks again for your time/reply..:thumbs:
On relatively low HP FI builds (550RWHP-625RWHP), when the pistons go, are they damaging any other part of the engine, or is it typically just the ringlands? Also, when the engine is rebuilt, is there any additional work which needs to be done besides the piston replacement, such as boring it over .005", boroscope inspection, full inspection, etc..
Just trying to get a better sense of what typically happens following this seemingly common failure mode. |
I wouldn't say this is a "common failure" the vast majority of stock piston LT1s are doing just fine. They are just limited to a certain HP, once you push past it you're going to have issues.
This thread makes it sound like supercharger will implode your engine on first start.
Keep it under 10psi, run it little richer, keep timing under 12-14, and have alcohol injection and you will be fine for long long time... I messed up my ring land by running race gas, 15psi, shit load of timing and i was just asking for... |
When the lands break we haven't seen them do any other damage. You Just get a lot of blow by and loss of power. We deglaze the cylinders, no boring.
Originally Posted by blown5.0
(Post 1596840690)
