Anybody Bother with Double Clutching?
I was wondering if the use of Active Rev Matching reduces wear on the syncros to the point where double clutching isn't needed anymore.
I thought double clutching died when synchro's were created.
The only vehicles I've owned where double clutching was necessary was a 64 VW Beetle and my current sandrail. |
Someone double clutches a C7?
It wasn’t necessary before ARM with modern manuals.
When you double clutch you blip the throttle with the transmission in neutral to spin the front part of the trans. and drive train up to match the speed of the rear wheels, correct?
If you have already done that then there is nothing left for rev matching to do.:confused2: For this reason though, rev matching is still not as good as an experienced driver since it is blipping the throttle with the clutch still in so only the engine speed is increased. |
I think you mean “does anyone rev match” any longer, maybe? |
Originally Posted by Superstar555
(Post 1596611683)
The M7 has triple syncros, yep 3 concentric syncros, one carbon faced! Have not seen a post re syncro problems since I got my September 2013 built C7, Z51. :yesnod: Transmissions are now using syncros in reverse (where selection is also blocked above a certain speed) so you don’t grind gears and make chips! |
No need to rev match, double clutch or anything else.
If you had a 1950s dump truck maybe. Rev match feature is mostly a gimmick for the avg guy same withe the "pop" you hear when shifting. Start, shift & drive. :cheers: |
Hmm?
What's a clutch?:eek:
Originally Posted by papillion
(Post 1596611987)
A mechanical device that manufacturers put in real sports cars. :yesnod: |
Why would you thinking double clutching helps a car with synchros up the ying yang, that doesn't need to be double clutched?:willy:
Of all my cars currently in my stable, this is the only one I double clutch...:flag:
https://cimg0.ibsrv.net/gimg/www.cor...c7516868c1.jpg |
We can thank the fast n furious movies for throwing this bs lingo out
Never heard the term 3/4 cam, stage 3 or full lope cam :lol::lol::lol: since the 70s. "Full bolt ons"? whats that? Everyone that had a set of headers, intake etc was still considered stock. Times have changed |
OP: Do you drive an 18 wheeler in addition to your Corvette?:rofl:
(Post 1596611978)
If you had a 1950s dump truck maybe. Rev match feature is mostly a gimmick for the avg guy same withe the "pop" you hear when shifting. Start, shift & drive. :cheers: It transforms average manual shifters into shifting pros, like those who actually know how to heel/toe rev match, and can do it perfectly 100% of the time. Proper rev match, which ARM gives you every time, reduces wear and tear on the clutch and transmission, and keeps the suspension planted and free from upset by jerky shifts. And to the OP, double clutching hasn't been necessary in street automobiles in at least half a century. |
Quite the response! ;)
I'll admit it's been a couple of decades since I tore into a transmission, but back then the syncros were brass and would eventually wear out as they were used. Based on the responses here, it appears that's no longer an issue. |
The last time I double clutched was when I had some bad noodles at a Chinese restaurant.
(Post 1596611683)
:lol: :lol: :lol:
FINALLY! A poster who must be even older than me! |
If you want to impress your friends learn to up and down shift WITHOUT using the clutch.
