The ZR1's Track Weakness: Fuel Consumption
I'm sitting here reading about how the ZR1 has a $2100 GG tax and the Z06 manual has none. I know from lots of experience that the C7 Z06 goes through 11 gallons in 30 minutes on track or "you better pit before you run out of gas" in about 42 minutes. Given the expected higher fuel consumption of the LT5 it'll be interesting to see how long it'll go on a tank when you're on it at the track. I have a suspicion it won't be much more than 30 minutes.
do you endurance race much?
Originally Posted by johnglenntwo
(Post 1596693478)
They have the same MPG spec?:crazy:
The EPA condones the catalytic converter car! They like'um Hot, I guess!:crazy2: |
yeah, on some high speed track a full tank of gas in Z06 only lasted me 37min before the low fuel warning shows up, maybe is time to buy a big fuel can, so we don't have to get gas every session
found something like this https://hunsakerusa.com/collections/...-quikfill-2-25 |
This is the type of can I use when taking fuel to the track.
https://wavianusa.com/red-5-3-gallon-gas-can.html I tow my car to the track and I carry at least 3 to 4 of these 5 gallon tanks with fuel for the Vette. I tend to dump in 5 gallons after every session to limit the giant fuel fluctuations of going from a full tank to near empty. Even though I only run 91 octane, fuel at the track pumps is bloody expensive. These tanks are so good you can haul them full of fuel inside your Vette and you won't smell any fumes or have leakage. These cans are actually rated for carrying fuel inside airliners during military emergencies. I actually carried one of these tanks from Sacramento to Salt Lake City and back in my Viper just because I knew somebody in our caravan was going to run low and gas stations are not too prevalent out in the deserts of Nevada and Utah. I don't think I could lift that 11 gallon fuel can without help, lol. |
Well! ;)
Originally Posted by Poor-sha
(Post 1596693030)
It's Not supposed to be a race car regularly getting an engine bump!:willy: That's it, he's going to put them in the poor house.:( The ZR1's days are numbered!:lol:
Originally Posted by dmaxx3500
(Post 1596693055)
I went thru more than 11 gallons in 30 minutes on the road yesterday, but it fun, guess I can turn the passenger seat area into a fuel storage area on the ZR1. :eek:
Let’s see. The engine makes more power, and has bigger injectors.
Track Weakness owner awareness!? ;)
NO AFM, RIGHT! VVT?:thumbs:
Purpose built via Trump's (Burn it down!) EPA!:rock: VVT!: http://autoweek.com/article/supercar...t-corvette-zr1 :cheers: |
(Post 1596693030)
You should see the fuel consumption of my 860hp, E85-powered Z06 in race conditions. I have never thought I didn't have enough fuel in that car to do the length of session I wanted. |
Originally Posted by Katech_Jason
(Post 1596701955)
I think the tires will start to go away before you run out of fuel.
You should see the fuel consumption of my 860hp, E85-powered Z06 in race conditions. I have never thought I didn't have enough fuel in that car to do the length of session I wanted. If you try those Pirelli slicks, they won’t go away even drive them hard for 40mins where all my fuel go away Frank |
Originally Posted by hcvone
(Post 1596694526)
Originally Posted by wwx8989
(Post 1596702857)
Hey Jason, just curious how much fuel does your E85 powered Z06 used? I thought the energy dencity are lower in the E85, thus you will need more fuel for same amount of power, and you are pushing 860 out of it:thumbs: If you try those Pirelli slicks, they won’t go away even drive them hard for 40mins where all my fuel go away Frank The stoich ratio of ethanol is lower so you need more fuel to reach the same lambda of gasoline. The energy content is lower but we are using more of it so it's a wash. Then you add on the additional power potential/knock mitigation of the ~105 octane E85, the intercooling effect of the alcohol and the fact that you're spraying simply more fuel volume (cooling the charge) and the benefits of E85 on a boosted car are incredible. All for $1.99/gal around here sometimes in the summer. I'm running the Katech surge tank system to supply the low pressure fuel to the engine, then the OEM DI pump with 38% fuel lobe to boost it up to DI pressure, then Katech +30% LT4 injectors to spray into the conbustion chamber. No meth. Pirelli slicks are on my wish list for this season. |
(Post 1596703199)
I'm using about 1/3rd tank in a 20 minute session...
I burn 11 to 12 gallons in a 30 minute session in my stock C7 Z06 (I have the GM 100 octane tune and run 93 octane plus Boostane to bring it up to 100). That would be a 1/2 tank in a 20 minute session. When I check the DIC after a 30 minute session it typically says I'm getting 3.8 to 4.0 mph. Two tracks I run are both approximately 3.5 miles long, and I about 12 laps in a 30 minute session. The only reason I'm getting such good mileage as 3.8 to 4.0 mpg is only because some of the slightly more than 40 miles is slow driving from the paddock to staging, an out lap, a cool down lap, and driving back to the paddock. With my C6 Z06 I could run two 30 minute sessions on one tank, but I'd be very low at the end of the second session. With the C7 Z06 I need to put in 11 or 12 gallons after a 30 minute session to get back to a full tank for the next session. I'm sure the C7 ZR1 will use even more gas!!! I thought cars running E85 got worse mileage. I'm really surprised that you get such good gas mileage on your modified car using E85!! . |
Originally Posted by BEZ06
(Post 1596703669)
Dayum!!! I don't know how you're getting such good fuel economy!?!?:confused:
(Post 1596703975)
Maybe it's a combination of things. There's usually significant warm up and some cool down in there. Also my home track is pretty tight so I'm not in full fuel consumption mode around most of the track. Only on the back straight. Or it could be that I just haven't been on the track in a long time and it's closer to a half tank and I'm not realizing.
I agree it's likely the track. What is the percentage of time at WOT?
You should bring that beast down to VIR. |
(Post 1596704444)
Yeah. I'm about 45% full throttle at VIR.
