headlamp issues
Hi
I a having troubles with the headlamps on my 63, The high beam is working fine but i have no low(dipped beam), I put in a new headlamp switch and tried a dip/floor switch out of my 59 chevy which i know works okay and both make no difference any suggestions as i must have power to the lights as the main beam works Thanks |
Your problem is from the dimmer switch forward - the headlight dash switch is uninvolved in hi/lo beam changes... Check grounds and that the connectors are tight, uncorroded and properly wired.
Check for voltage at the socket.
There are only a few places your problem can be. The connector coming off the dimmer switch (tan wire), the connection in the outboard firewall connector that the tan wire passes through, a break in the tan wire from the dimmer to the connector at the front driver's fender, and the junction in that connector where the tan wire splits to go from the driver's side to the passenger side (a very common place for a corroded connection).
I assume all four bulbs come on when on bright. If not, you can eliminate all those and go directly to either the connector at the back of the dim bulbs at the grounds (black wire). Again, if the dim bulb does not work on either bright or dim, you have two bad grounds (one for each dim bulb, they don't tie together until the ground screw at the radiator support) OR both dim bulbs are bad. If all four bulbs work on bright, but no dim bulbs, go back to paragraph one and find the problem with the tan wire. |
Thanks i will check these out,Yes it lights up all 4 lamps on main so looks like the tan wire you mentioned
Originally Posted by tikiwagon
(Post 1596708323)
Any luck yet?
Just been down the garage and all sorted cleaned all the plugs up and they are working a treat again
Thanks for your help Cheers |
All seemed to be working for a while but been out a couple of times at night recently and when on High beam the lights are flickering on and off a lot when back on low/dip they seem okay, I pulled apart all the connectors recently and cleaned them all up even though there was no obvious corrosion and took the earth wire off the rad support and gave that a good clean but it still happens, Any ideas?
That's a faulty headlight switch. Probably when you put in the one that didn't fix it. If you still have the original put it back in and it should solve your problem. the breaker in the repro switches is not strong enough to handle the bright beam current
You may have to eventually put in relays to cut down the current draw on the headlight switch if you can't find one that works.
Okay thanks i will try the original again and see what happens
If you truly have an original "095" headlight switch they are one-year-only, rare and valuable. Its worth reconditioning it...
Just got the old one out, It is a 096 what is the difference and will it be okay?
It’ll work just fine and should support the high beam current draw.
I will give it a clean and try it, Thanks
As long as the dash light dimming rheostat isn't fried you can open up the switch (beware the small parts) and clean the contacts (I prefer DeOxIt) and lube everything lightly - reassemble using a wire to get the tabs on the metal housing just started then remove the wire and secure the tabs. An "095" switch has a distinctive fan-like wafer in front of the rheostat - nobody knows why but some say it was for cooling. The second picture is the thermal cutout that strobes the lights in an over-current condition - this is a weak part on the repros.
https://cimg0.ibsrv.net/gimg/www.cor...ef008dddb2.jpg https://cimg1.ibsrv.net/gimg/www.cor...2d0648bc3a.jpg https://cimg5.ibsrv.net/gimg/www.cor...cb4e90dd7e.jpg https://cimg9.ibsrv.net/gimg/www.cor...da35708032.jpg https://cimg0.ibsrv.net/gimg/www.cor...3bd6914f02.jpg |
Fantastic help I wont get the chance to strip it as using it in next few days but will take it apart in next week or two
Thanks again |
Just found out my one that is in the car is a 095
