Clutch fluid still good?
Purchased some DOT4 clutch/brake fluid last summer and performed the Ranger method fluid change a couple of times. It has been stored with the cap tight and in a zip lock bag. I have seen many comments about the fluid being hydroscopic, thus any concerns using the remaining fluid to flush again?
Also, any thoughts on synthetic vs non-synthetic fluid? Thanks Jim |
Shouldn't be a problem. I use Valvoline DOT 4 that says synthetic.
I believe all brake fluid is synthetic.
It is hard to say about the stuff in the zip lock bags. Some bags may not be an effective moisture barrier. They may slow it down but not prevent it. Others may be true moisture barriers. The only way to know is to try it. At least it isn't a safety issue like the brakes are.
I put my opened containers in a zip lock bag but if they have been in the bag for more than two months I don't use them. Bill |
There are some fairly inexpensive electronic brake fluid testers out in the market( I got mine from Amazon). I tested my Dot 4 I had sitting about for about a year, it registered it had about 8% moisture, but when I tested my clutch fluid, the moisture reading went off the scale. I would buy a tester to test your fluids you have had sitting around a while just to be sure. You would also be surprised to see how much moisture is n your brake master cylinder fluid. Brake fluid needs to be changed a well
A fresh bottle of brake fluid isn't that much. Why spend $$ on a moisture tester that won't be periodically calibrated? Unless, of course, you just want more toys and gadgets.
Ron |
Originally Posted by RonC7
(Post 1596725685)
Ron In my former life we tested many ways to package welding wire. The worse was a sealed plastic bag! Thin plastic is permeable and water vapor (and other gasses) pass through it, albeit slowly. If it's a plastic container it will take longer because it is thicker. A metal can was used for the most expensive 140,000 yield strength welding wire used to fabricate some small mini submarines, etc. Best for others was what is called vapor-paper that is chemically coated. |
My .02... When I do the ranger method (every time I do an oil service) I use the whole bottle of fluid, nothing to save....
:iagree: Same here! Prestone DOT 4, $4 for 12 oz at Walmart. Good enough for me as I don't track. |
Yeah, I just did it a few weeks ago and have waaay to much left over (I got the mega size bottle) but I am scared to re-use so I hear ya. I have the garbage GM flywheel issue with hot spots I have been fighting GM about, so I will be doing a clutch package soon anyway but it DID improve my shudder at low speed doing the ranger method.
Tightly capped SB fine.
Fluids are cheap..."When in doubt,throw it out" BTW....the OE fluid is made by Pentosin. \db2 |
Originally Posted by JerryU
(Post 1596736096)
May be okay; but I give up, why not just use new to be sure? It isn't like it's going to cost an arm-&-leg to do so. Maybe in a junker to sell, but... come on.
Originally Posted by BELVIN20
(Post 1596724899)
It appears to be a resistivity measure with two probes. Readout is several colored LEDs. Easy thing to check as I will have old fluid and new from a just opened container. Will also leave some of the old fluid exposed and check all measurements with a quality digital VOM! Reminded of the simple meters used to measure wood moisture. Also how can it be possible to make, sell and ship for $3? :crazy: Will be a fun experiment. |
Originally Posted by javenius
(Post 1596739741)
Any issue with synthetic vs non-synthetic?
Just checked and have a few ounces of brake fluid left in 12 oz cans from Prestone and Valvoline in my Ranger kit. I trust the brands, the SAE specs they say they meet and Walmart turns inventory very quickly! I'll check those two old containers with the test mentioned above (not sure why I didn't throw them out as I would never use them!) As some have mentioned, it's too cheap and a 12 oz container will be mostly used with the Ranger method! For those who have not used the Ranger method, pics below are the results from the first Ranger flush I did after a year in my 2014 C7. With 30 pumps of the clutch after each empty/refill of the reservoir, it shows, IMO the fluid does mix with the slave cylinder. GM says the dark color partly comes from the throwout bearing seals, which is no doubt true. The Ranger method appears to replace most of the old fluid. https://cimg4.ibsrv.net/gimg/www.cor...cd8a43a1cb.jpg https://cimg5.ibsrv.net/gimg/www.cor...3841ea32b2.jpg https://cimg6.ibsrv.net/gimg/www.cor...b1c0c0ac8c.jpg https://cimg8.ibsrv.net/gimg/www.cor...f0239a5fd5.jpg https://cimg9.ibsrv.net/gimg/www.cor...02b811de9d.jpg |
Save the wear and tear on your left foot and leg. Do a real bleed to get fresh fluid into the slave.
Originally Posted by 3X2
(Post 1596777138)
And all you are doing is changing the fluid in the reservoir. Not the master cylinder, not the line, not the slave. But the reservoir does have clean fluid.
(Post 1596777453)
Look at my post #15. That 30 pumps per replacement in the reservoir does more than just empty fill it with new fluid. Fluid does mix in the master cylinder or it would not get progressively cleaner after 6 dump/replace cycles. May not get a high percentage of the slave cylinder although again look at the Ranger info and he shows it does! He is a drag racer where there is a lot of clutch material entering past the slave cylinder seals. He finds the method works for him as do many of us! Understand your argument, it has been raised before and the answer may fall between your-no mixing and Ranger mostly mixed! IMO a once a year Ranger use is as good as an every 3 years (as recommended in the Owner's Manual) bleeding from the slave cylinder. However that requires removing the drivers' side Catalytic converter and exhaust pipe and some of the sheet metal covering the exhaust pipe. Then bleeding from the slave cylinder fitting. A PIA and >$150 dealer cost assuming they do a good job! Don't expect you to change your mind as it is obviously made up but perhaps these comments will help the ~500 silent majority who have viewed this thread versus the ~10 of us who have posted! :lol: Been only using the Ranger method at oil change time since I got my 2008 Z51 C6, then my 2014 Z51 and will my Grand Sport soon, as the oil change is coming up! Never had a clutch problem! :yesnod: |
(Post 1596777453)
