RPO codes on '10 GS, not in glove box.
Looking for the RPO codes for a 2010 GS coupe. We looked in the glove box and nothing. We also looked at a 2012 glove box and no codes. Where else would they be located? Thanks
On the inside of the door on the glovebox.
Sit in driver seat open glove box RPO tag is on outside of glove box facing driver side. The tag is on not in the glove box |
Sticker is hard to see but I'll bet it is in there. Look again.
Originally Posted by cadyshac
(Post 1596765119)
Sit in driver seat open glove box RPO tag is on outside of glove box facing driver side. The tag is on not in the glove box I've owned 5 C6s and all 5 of them had the RPO tag in the same place: In the glove box, on the extreme left side of the glove box door. Others here have said they couldn't find it UNTIL we told them it was on the INSIDE of the glove box door and on the EXTREME LEFT SIDE of the glove box door. Get a strong flashlight and put your glasses on and look again. If it's still not there, then someone tore it out before you got there. Go look at 20 other C6s with that flashlight and those glasses on your nose and you'll see what I'm talking about. |
This is the view from my drivers seat, clearly visible.
https://cimg9.ibsrv.net/gimg/www.cor...bbb9ad118f.jpg |
Originally Posted by Oh Boy
(Post 1596765389)
It's French and it's the airbag tag.
However the RPO sticker is right where it belongs, and is gray (maybe silver-ish). |
I don't see it in mine or the 12 we looked in.
Originally Posted by 919cw313
(Post 1596765582)
Originally Posted by Vette_DD
(Post 1596765603)
It's not visible in that pic.
(Post 1596765610)
You need a better monitor. It's there, you don't see the GM holograms?
(Post 1596765610)
It's also difficult to be sure what part of the glove box or dash I'm seeing. However, it's extremely unlikely that a tag with RPO codes on it would be visible from the driver's seat if the glove box were closed. I can see the 7 lines of RPO codes on the tag in the pic that MidLifeC6 posted. But even that pic, it hard to be sure where the tag is. However, it looks like it's in the glove box. But if your RPO tag is outside the glove box, fine. You just have one that's put somewhere that few C6s have. :leaving: |
(Post 1596766026)
I've got a 2 year old 27" monitor and a pair of 2.75 reading glasses, but I'm not seeing anything that looks like an RPO tag with 50-60 RPO codes on it.
1 Attachment(s)
The RPO codes are there, you just can't see them clearly in the picture due to the GM holograms showing as a result of the angle the picture was taken and/or the flash from the camera :cheers:
So according to all the posts the left side of the glove box is the only place GM places the RPO sticker. If sticker is not there and there is no alternate location then we must assume either the glove box has been replaced or the sticker has been removed? No stickers on two different year C-6's is pretty strange.
Originally Posted by cmonkey713
(Post 1596767158)
(Post 1596765603)
(Post 1596767158)
