Oil change question..
i have amsoil motor oil in my car that has afew hundred miles on it..my question is i put the car away for the winter..would you change the oil again even though it has afew hundred or leave the old oil? Thanks!
I wouldn't change it due to the time - I'd change it because it's Amsoil.
Originally Posted by Ed Ramberger
(Post 1596816500)
Nothin' wrong with Amsoil, just overpriced.
LOL!
AMSOIL Signature Series 5W-30 is the Best Oil you can run in your Stock or SBE Modified LS Engine. Change the Oil after one Year or when it comes out Of hibernation for spring. The TBN is higher than any other Oil in its class and will resist acid formation accordingly. |
Originally Posted by juanvaldez
(Post 1596816666)
Walmart depending on grade and application, Also delivered to your home or business. PM for details if interested. |
(Post 1596816666)
Originally Posted by 04zjimc
(Post 1596816474)
I wouldn't change your oil with only 3-400 miles on it. I believe it would just be costly and wasteful. The Corvette Gods will not punish you for not changing the oil after the winter. And my understanding is that Amsoil is a quality oil. |
Originally Posted by bc6152
(Post 1596816775)
Change your oil before the next hibernation
What's hibernation???? Us Floridians have never heard of such a thing. AMSOIL changed every 10k.
I use "proper" Mobile 1 and change it every two years, 4000 miles. More frequent is just a waste. Amsoil isn't available at my local retailer and the correct oil has worked fine for 16 years so why switch?
(Post 1596816775)
(Post 1596818755)
:iagree: I have the same issue with mine - only put about 500 miles on mine since the last oil change and can't see changing it with that low mileage on the oil.
(Post 1596816500)
I did have another question..i used amsoil 10-40 zrod..and was thinking should i switch to the 5-30 signiture series the correct oil..i did notice with the zrod my motor ticks alittle more.
Originally Posted by Navy Blue 210
(Post 1596816685)
LOL!
I would not change it at this point. I would do it when it reaches 3000 miles or is a year old.
I think that just about any name brand full synthetic oil manufactured today is excellent.
I use Valvoline Platinum in my DD Lexus and change it myself. Mobil, Shell, Amsoil, Quaker, Castrol, they're all high quality oils and last a long time IMO. |
Originally Posted by glbeauchamp
(Post 1596819377)
That's what I use. And it's manufactured about five miles from here. I can get it fresh from the cow, so to speak.
