Light weight C5Z
We have a customer that put his C5 on a pretty intense diet. Theres still several pounds left to remove, but this is a pretty decent start. The only "light weight" part on the car is the 1 piece carbon hood and the shorai battery. Everything else has simply been removed.
The car is being set up for NASA TT3 or TT4.
https://cimg9.ibsrv.net/gimg/www.cor...89838b8fb8.jpg https://cimg0.ibsrv.net/gimg/www.cor...0c657c2f23.jpg https://cimg2.ibsrv.net/gimg/www.cor...3cdb7ed148.jpg https://cimg4.ibsrv.net/gimg/www.cor...bd8b93edba.jpg https://cimg6.ibsrv.net/gimg/www.cor...b63ebd7864.jpg |
I'm looking at that list and still struggling to see how he lost nearly 500lbs. That's nuts! :eek:
Originally Posted by Quickshift_C5
(Post 1596839793)
Originally Posted by Olitho
(Post 1596839981)
No cage or fire system. Most cars stripped like that are also caged.
1 Attachment(s)
I'm right there with you with my c6.
David, Louis are you guys running at that weight or ballasting up for TT3/4? You would have to take a lot of power out otherwise. When you ballast up though you can put it where you want and where it will be most beneficial.
Originally Posted by Kubs
(Post 1596841717)
the hard part is that to get this car on a 275 in TT4, you have to weigh 3100. The advantage is that now we can place the weight advantageously, and have a better car with a lower Center of gravity, and less pendulum. right now, full fuel, and driver, we’re roughly 2900lbs. |
What is the brown mat under the lift? Did you pour a setup plate to do alignments?
Originally Posted by GSpeed
(Post 1596842375)
it depends on the class. This car has very little rear weight, but we only have to manage 250ish Rwhp. We plan to test both weights and power levels. We aim to be as light as possible, and then detune power to that weight. the hard part is that to get this car on a 275 in TT4, you have to weigh 3100. The advantage is that now we can place the weight advantageously, and have a better car with a lower Center of gravity, and less pendulum. right now, full fuel, and driver, we’re roughly 2900lbs. |
Originally Posted by fatbillybob
(Post 1596842492)
Originally Posted by mattastick
(Post 1596842771)
Can you go down on tire with a lower weight? Since it's no cage, I assume this is time trial, not wheel to wheel, and you don't need the tires to last that long, so you can run smaller. Bonus is that they're also lighter, the wheels are lighter, etc. etc. etc.
we have some 245 scrubs to test, but no wheels yet. Certainly a test, but something we have yet to do. Yes, it’s a TT car. |
Can we lower speccorvette to 3000lbs then:willy:
(Post 1596839981)
I agree with Olitho. Once this car is safe to race with a full cage etc, you will be more 2900 range without driver. Those last pounds are hard to find!
Originally Posted by cwikstro
(Post 1596843774)
Originally Posted by davidfarmer
(Post 1596840263)
Got the car on track today for the first time after some significant mods, and its working quite well.
Splitter has .300" of rake chassis has .500" of rake front ride height at rest on the center of the cradle is 3.75", rear is 4.200 at the frame rail by the jack puck location. https://cimg0.ibsrv.net/gimg/www.cor...8e644236d9.jpg https://cimg1.ibsrv.net/gimg/www.cor...f74f21fadd.jpg Going to do a little more work this weekend during the Drivers Edge event to see if we cant take another 10/20lbs out:cheers: |
Please can you ask the owner to share how he put that splitter together, what parts he bought and what he fabricated to go under the stock front end.
(Post 1596843053)
[left]
yes, 1” self leveling epoxy. |
Originally Posted by Garry_W_C5_1999
(Post 1596847078)
https://cimg2.ibsrv.net/gimg/www.cor...0fd7beec2.jpeg https://cimg3.ibsrv.net/gimg/www.cor...78e0a4a28.jpeg |
(Post 1596847179)
Is the setup epoxy plate something you did yourself? Can you post about how you did that and with what materials? I'm so tired of getting a flat floor with flooring tiles.
let me see see if I can find any info. It’s about 12 years old at this point, but has held up well. Had a C5 trans leak on the pad turning it pink, lol, and some knuckleheads welded on it melting it slightly; but not bad otherwise! |
(Post 1596844982)
I agree! We will document it all. We have built cars as light as 2600lbs endurance ready with no driver no fuel in the past, just Depends on how much money we want to spend. Carbon bodywork is a large gain, and cost. |
