Help on c6 speaker selection/setup
I know this has been talked about before but, I couldn’t find anything recent or with my desired info. Anyway, I have a z06 with the Bose system in it and currently have a nice pioneer HU and a jl stealthbox with a Rockford Fosgate punch 500w amp wired in on the back wall of the hatch. I will be replacing the sub in the box as it is currently an old kicker that isn’t too good. That is straight forward but I need to find a sub that fits the depth of the jl steathbox and can handle the power of the amp. The stock bose door speakers get fairly distorted when you turn up the volume and are not clear and crisp like how I want them. What would you recommend for replacing the door speakers and how would I wire them into the system since they have the bose setup. I don’t want to spend a boat load on this but I do want a good system that can handle being turned up a bit (my car is very loud with the exhaust valves open). We have a jl system on our boat that is excellent but I am open to other ideas. I just need to know everything I will need to make this a fairly easy swap and not a long project :confused: |
Man...where to start? The sky really is the limit here. Since there's a 10" hole in the doors, you can literally fit ANY speaker in there. Personally, a 6.5" component set easily gets the nod from me. But speaker brand or particular set is really up to you. There are hundreds to choose from. I'm a HUGE fan of Focal. I've never heard a speaker of theirs sound bad. However, they can be pricey. For a mid to entry-level (and mid to entry-price) Polk makes some pretty good sounding speakers at a non-premium price. I also am a fan of Boston Acoustic, but I wouldn't run bostons without an amp. Stay away from Sony and Kicker. They are too low-end for a ZO6 IMO.
Originally Posted by Pb82 Ronin
(Post 1596882762)
To do this right, you need to replace the door speakers with a good quality set of 6.5" components and also an amp to power them. They sell the adapter plates on Amazon for the woofer location and also the plates or cover for the 3.5" speaker location. The tweeter goes where the 3.5" speaker currently is. In my case I cut a hole on the 3.5" cover to mount the tweeter. The woofer door plates need no modifications.
Here is my old thread about my speaker search. You can look through the pictures to see the end results. I also did rear speakers which is a personal choice, but for simplicity sakes a good set of fronts and a sub all run by an amp is all you would need to get a nice system in a C6. https://www.corvetteforum.com/forums...need-help.html |
Definitely get an amp and a speaker set with external crossovers. Distortion is caused by several things. Playing a frequency outside of the speakers limit. More power than the speaker can handle. EMI, etc. RCA's connect from the head unit to the amp, then amp to speakers/crossovers.
Adapter plates can be purchased from a number of places like here: http://nakidparts.com/id28.html Absolutely put the tweeter in the stock location. you can play with angle rings to get the components pointed in the best position for the sound stage. When it comes to audio, I'm a SNOB! I can't stand cheap anything in my cars. Certainly don't skimp with wires. The actual "speaker wire" doesn't have to be super high end, but I prefer the BEST POSSIBLE RCAs from the HU to the amp. And NEVER run power/ground wires next to, on top of, or around (if you can help it) signal wires. The EMI can crush the performance of even the highest end systems. |
The door plates I used: Metra 82-3014 speaker plates for the woofer, and Metra 82-3015 for the tweeter location. Ignore the info for the 82-3015 tweeter plates, they are listed for the C7 but they are the same for the C6.
(Post 1596884050)
Originally Posted by jmoney127
(Post 1596884238)
So I would need an additional amp to go along with my current one? Or can I wire in the current amp to the speakers as well? |
Originally Posted by TorchRedFred
(Post 1596884304)
It depends on your amp. It sounds like you have a 1 channel amp for a subwoofer. If you have a one channel amp, then yes you are going to need another multi channel amp to either power just your speakers or your entire system.
Do you know the model number? You are going to need a minimum of 3 channels. 2 channels to power your front speakers and a sub channel to power a subwoofer. If you have a 500 watt amp, chances are it is a single channel.
(Post 1596884357)
(Post 1596884857)
Ill have to look later today. Is there anyway to get good sound without adding another amp if it is only a one channel? |
(Post 1596884973)
No. If you plan on adding some good aftermarket speakers, you will need an amp to power them. The power coming out of a normal head unit won't be enough to power good speakers.
(Post 1596885147)
Is there an amp that will drop in to where the bose one is under the passenger footwell? I want to do as little wiring as possible as I do not like doing it. I would pay someone to install it but there are no audio shops around here that I would trust with my car. |
(Post 1596885404)
I'm not sure. But you may be better off or it may be easier just to run the RCA cables for the font channels from your head unit to your current amp location and then just replace your amp with one that can power your speakers and your sub. From there you would just need to run speaker wires back to the doors and install the speakers. You may have to do a little research just to figure it all out but it's not that complicated since some of the wiring is already done for you. You would have to check the existing power wiring and make sure it is sufficient for what ever amp you decide to use if you go with something more powerful.
(Post 1596885753)
That helps me understand the system a bit better. So I need rca to amp, amp to sub, amp to speakers? Speakers are not directly connected yes to the HU then? How difficult is it to run the wiring to the doors? |
Also, you will need to disconnect the dash speakers and the stock rear speakers from either the head unit or from the Bose amp under the passenger foot well. They won't be able to keep up with an after market system so it's best to just disconnect them.
TorchRed pretty much beat me to all of it. All good info here. In my past experiences, it's begging for problems when trying to make 2 systems work together in harmony. I find it's FAR easier to just remove the stock junk and replace it with quality stuff. Keep the junk for when you want to reinstall it to sell the car. If you're never selling the car, kill the stock crap with fire.
(Post 1596886442)
(Post 1596887138)
I wasn’t planning on trying to run any of the bose speakers with the new system for that reason. What does a crossover do and how is it wired in? I know how to run the wires through the interior but haven’t ran wire from the interior into the door panel before if that makes sense. I’m assuming it just goes through the factory harness “protector” or whatever it’s called and to the speakers? Is it worth it to just do a set of 6.5 and tweeters with my 10” sub or should I replace the rear speakers too? Learning a lot here! As far as rear speakers, that's a personal choice. For simplicity sakes for a novice, I would suggest spending your entire speaker budget on the best set of front components you can afford. When you run rear speakers, you run into issues with time alignment and you may or may not like or feel like its worth the efforts. With a good set of fronts properly installed, you will never be able to tell where exactly the sound is coming from and most people would never be able to guess that there are no rear speakers. A good set of 6.5" components and a proper 10" sub are surprisingly plenty for a C6 cabin. As far as running wires into the doors, there is a cover that is on the inside of the car cabin under the dash that wires run through into the door. You have to remove that cover first by reaching up under the dash, then you just use a coat hanger or something similar to run the wires into the doors, along side the other factory wires that go into the door, and then put the cover back on at the end. But just leave a little extra wire or slack so the doors can close and not pull the speaker wire. |
