Hood louvers/vent for zr1
Who makes the hood louvers to replace the hood window on the c6 zr1? I've seen them on a couple cars, just can't find them online. Thanks. |
ACS Composites |
Originally Posted by SIK02SS
(Post 1596901054)
ACS Composites |
Does anyone know the steps to remove the oem hood window?
Heat gun at about 750* and push it out.
Thanks! And which sealant for new vent?
OP, there is likely some useful information in this (older) thread...
https://www.corvetteforum.com/forums...ce+hood+window |
Originally Posted by chassed
(Post 1599047823)
Loctite PL premium. You can get it at Lowes or Homedepot. |
Originally Posted by Texasthunder
(Post 1599045678)
Just be sure to move the heat gun around the window (inside of hood) where the adhesive is located. Don't hold the heat gun in one spot to long or you could damage the paint or window. You can use a flat blade screwdriver to help separate the window from the hood. The adhesive should start to release at around 350*, but it take forever at that temp . |
