Electric heating elements instead of heater core???
I am doing a complete rest-mod of my 80. One thought I have is replacing the leaking heater core with a 12v ceramic 400w core instead.
This would eliminate any leaks and clean up the engine compartment of hoses. Yes I will need to fabricate a mounting system and a control system. I just want to update it to the 21st century instead of early 20th century technology. Just like an AM-FM-BT radio in place of the analog radio. The plan is to finish it this year. It was to be a 3 year project but with major health issues and old age coming on it turned into a 14 year project. Full frame-off, all parts were either rebuilt, refurbished or replaced, including a fully adjustable coil over suspension. Not a racer just a fine driver. Your thoughts? :thumbs: |
I think that it would be a huge power drain and probably a fire hazard.
I’d vote for replacing the heater core. Definately a PIA, but in these cars, that isn’t unique. |
My Volt has a heater core. The electric element is immersed in coolant.
Since I'm in the "south"-
Most the time its hot and if it's cold- more than likely not driving my C3. I got rid of the heater core- added Vintage Air AC using an electric AC compressor. Put heaters in my Corbeau seats and added small ceramic heated blowers in the dash to defog. I haven't seen anything that's efficient on a 12VDC system. The electric cars are running 208V. Defoggers- https://cimg0.ibsrv.net/gimg/www.cor...f56f68bcbe.jpg Custom dash with vents- https://cimg2.ibsrv.net/gimg/www.cor...82d4b47e04.jpg Covered in leather- https://cimg4.ibsrv.net/gimg/www.cor...bab0d4916e.jpg They don't get that hot- will defog- but not defrost... https://cimg5.ibsrv.net/gimg/www.cor...a4c0b492bd.jpg The rest of the dash https://cimg6.ibsrv.net/gimg/www.cor...2de46e1f8a.jpg |
I have to admit I've never heard of anyone using electric heat on a 12 volt system. I'll be interested in hearing if it can be made to work. If I remember my high school electronics correctly, a 400 watt heater running on 12 volts would be drawing about 33 amps. That's a significant draw. Upgrading the alternator would probably be in order.
You say 20th century versus 21st century. Do you know of any manufacturer in the 21st century using an electric heater for a internal combustion engine powered vehicle? Replace your current heater core and you will never have to replace it again and invest your energy into other aspects of your project.
The problem I see other than a large electrical demand is that a 400 watt electric heater is not going to produce much heat. It’ll get good and hot but the volume of hot air is going to be minimal.
So I guess it might depend on where you live and how cold of an environment you plan on driving it in as to the level of success you’ll see. A really good source of heat after the engine warms up is all the hot air under the hood, hole in the firewall and wala, heat. |
Originally Posted by Richard454
(Post 1596917920)
Most the time its hot and if it's cold- more than likely not driving my C3. I got rid of the heater core- added Vintage Air AC using an electric AC compressor. Put heaters in my Corbeau seats and added small ceramic heated blowers in the dash to defog. I haven't seen anything that's efficient on a 12VDC system. The electric cars are running 208V. 400W is not going to keep you warm, though, but as was pointed out, that's about 30 Amps when the Alternator is charging the battery. The two units Richard shows are 150W each, or about 12 Amps each. Either way, you'd probably want a relay (or two), wired so they can only turn on when the engine is running. https://amzn.to/2GyD0GI My heater core is out right now. I might have to try this solution. It's amazing how widely varied the Amazon reviews are for these defoggers, though, when clearly there are only one or two manufacturers selling under many names. |
Lots of good thoughts out there. This is just something I am considering for the final phase of the build. I feel it is doable but more research is needed into the power requirements.
I tried to copy the picture but could not do it. here is a link https://www.banggood.com/400W-12V-El...r_warehouse=CN The wires look a little light for 33 amps. Q and A says 200 degrees at 40 degree ambient air temp. |
1 Attachment(s)
I had found a bunch of interesting info on some Electric Vehicle forums when I researched this. I came to the conclusion that the stock heater core (or equivalent replacement) is tough to beat if you need "HEAT!". It is the equivalent of several Kilowatts worth of electric heaters. To do the same with electric heat, you would need 10 of those 400 W units. Can your alternator put out 300 Amps? How about 1500 Watts, but at 200 VDC?
http://www.evwest.com/catalog/produc...roducts_id=335 The other benefit of using radiator fluid is that it is limited to about 200 degrees. Hot to touch, but fine for most car parts. That ceramic heating element will melt plastic if air isn't flowing over it. To safely use in a car, you would need some additional circuitry (perhaps an Arduino, or equivalent) to ensure that the blower fan is running, and you don't have a temperature spike. It wouldn't be a big step from there to actively control the cabin temperature, though, so that may be worth it to you. This guy came the closest, but he's running off of a 140 VDC traction pack. Read the comments for the fire hazard warnings: http://b2600ev.org/making-the-electric-heater-core.html For a defogger, electric heat all the way! Jegs and other sell alternate heater cores if you don't mind using radiator fluid to get your heat. |
Originally Posted by REELAV8R
(Post 1596920065)
A really good source of heat after the engine warms up is all the hot air under the hood, hole in the firewall and wala, heat. https://cimg2.ibsrv.net/gimg/www.cor...b5860bcd1f.jpg
Originally Posted by indy99
(Post 1596921377)
The wires look a little light for 33 amps. Q and A says 200 degrees at 40 degree ambient air temp. The 12VDC is converted to AC- separate power supply to run the motor https://cimg3.ibsrv.net/gimg/www.cor...cb359fbf71.jpg https://cimg4.ibsrv.net/gimg/www.cor...98a344248e.jpg No way this piece will see 200º or the wires handle 30+ A.... https://cimg8.ibsrv.net/gimg/www.cor...9b06a0001b.jpg My heated cupholder maxes out at 133º https://cimg1.ibsrv.net/gimg/www.cor...cefb082cce.jpg https://cimg3.ibsrv.net/gimg/www.cor...79672375c1.jpg |
Heated cup holders?:crazy:
You building a Corvette or a Bentley?:rofl::rofl::rofl: |
Originally Posted by Big2Bird
(Post 1596922724)
You building a Corvette or a Bentley?:rofl::rofl::rofl: Came from a Cadillac Escalade! |
(Post 1596920065)
So I guess it might depend on where you live and how cold of an environment you plan on driving it in as to the level of success you’ll see. A really good source of heat after the engine warms up is all the hot air under the hood, hole in the firewall and wala, heat. The PO's solution to this was to drive around with the window open! Old V8's are very good at turning fuel into heat rather than effective work :thumbs: |
Here i go...
My first vette a 72 bb convertible ac car had a big hole in the evaporator box and even in cold weather it cooked, in hot fl days it was unbearable, I patched it and could drive the car without melting, This idea applied to some air cooled vw trike stuff, Guys in the trike club wanted heat, lol , on a open cycle, ha, But some clever guys used the stock vw heat exchangers ducts and inline fans to bring heat to their front in the faring No, it wasnt like heat in a car but it did hit the drivers in ways that the ones who did this loved it, As a modder, nothing is impossible but some things are not practical enough to persue, like electric heat in a car, The idea reminds me of the very eccentric kit car guy i knew used the smallest ac wall, yes wall ac unit in the back of his laser 917, He had a smallest i ever seen weedeater motor running a generator for ac power, He had his reasons why he didnt want the vw engine to run the little generator, He had ac wall outlets in the car, no kidding, Practical? Not in my mind but so outsude the box i loved it, Froze him out of the car, The car also shot 20 foot flames for fun and used a zillion volt stun gun guts for theft deterrent , On a vette, i would believe a heat exchanger on one or two header pipes ducted into the cockpit with forced fan, would cook you out of there, and its simple. :leaving: |
I'd worry about sucking a piece of something flammable into it.
