C4 Road Race Car
https://cimg2.ibsrv.net/gimg/www.cor...89f2fd81be.jpg
https://cimg4.ibsrv.net/gimg/www.cor...33698efd13.jpg https://cimg7.ibsrv.net/gimg/www.cor...37e1046a49.jpg https://cimg0.ibsrv.net/gimg/www.cor...3d928015d6.jpg Chassis: Pro built 1 3/4” road race cage Vette Brakes heim joint rear control rods (dog bones), toe rods and camber rods Fuel Safe fuel cell 96 bodywork, 20 foot paint job Light weight roof panel Gutted doors (still operational) Kirkey intermediate seat and cover (14 1/2”) Custom dash Autometer gauges (Tach, right and left cyl head temps, oil pressure, volts) Digital GPS speedometer Stock tilt/telescoping steering column and wheel 5 point harness Poly front “A” arm bushings Bilstein shocks 84 Z51 springs (Very Stiff C4 springs) 84 Z51 steering rack (Least turns lock to lock) Front spoiler Carbon fiber rear wing Be Cool aluminum radiator Electric radiator fan with thermostat and override Grand Sport front calipers with 13” cross drilled rotors “A” mold 5 spoke wheels Switch panel (Master electric, push button start, fuel pump, fan override, lights) Drive Train: From New L-98 engine (worked by Cotrell from what I was told.) Cam Jegs gear reduction starter Plugged center lifter valley drains, chamfered front and rear drain Mostly ARP fastners .030 over Ross forged pistons Tapered and coated wrist pins 0 decked Felpro .040 head gaskets About 11.1 compression 58cc 113 heads 1.6 roller rockers Trick Flow Chrome Molly push rods Weiand X-cellerator intake manifold Race Demon mechanical secondary double pumper carburetor Holey Blue electric fuel pump Adjustable fuel pump regulator Braided fuel lines with Aeroquip AN fittings Moroso plug wires MSD Billet Distributor MSD 6AL ignition MSD Blaster coil 10 Quart Champ road race (baffled and trap doors) kickout oil pan Edlebrock high flow water pump Water pump driven Powermaster alternator Underdrive pullys (V Belt) Lightweight GM flywheel TPIS Headers 3” exhaust 3 puck clutch disc ZF 6 speed transmission Dana 44 rear end Extras, not installed: Power Steering pump, pulley and mount Oil cooler Oil temp gauge Extra ball milled brake rotors 8 sawblade wheels 2 rear tires Flowmaster Outlaw mufflers 5' 3” exhaust tubing 2 3” 180 degree u bends (for making turns in the exhaust) Turn signals, brake lights, led headlights installed for street use. Needs a little to finish for the track, or drive it as a street rod. $15,000 O.B.O P.M. me for more pics or info Mark |
Price drop!
I bought a C6 Z06 and need this thing gone to a good home. $13k or best reasonable offer |
Sorry I am not interested in buying your car as I have a C4 track car of my own, but I was wondering if you can let me know where you got that front spoiler?
