Are you ready?
3 Attachment(s)
ARE YOU READY??? * CNC billet machined componentsThat’s right are you ready to take your C7 to the next level in suspension tuning and handling? Introducing the Nitron Pro Race 3 Triple Adjustable Coil-Over w/remote reservoirs. 3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. The remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping. Our World class compression adjuster- means Nitron shocks have the widest range of useful adjustment available on any mono tube gas shock * Completely re-buildable/re-valvable * Teflon coated pistons for consistent damping control * PTFE Lined Bearings * Induction hardened super polished chromium plated piston rods resist corrosion and wear * Low friction rod seals, double acting rod scraper, and progressive bump stops * Stainless steel carbide hydraulic hoses with 360 degree Bi-Axis fittings * Ultra low friction bearings, brushes, and seals for precise damping control * Exceptional range of fully sealed damping adjustments * Extensive range of spring rates for Street, Track, and Race applications * Each shock is hand assembled and backed by Nitron’s 2 year warranty and US based support facility http://www.xplosiveperformance.com/N...er_p_4196.html Attachment 48273662 Attachment 48273663 Attachment 48273664 |
Are you ready???
2 Attachment(s)
ARE YOU READY???
That’s right are you ready to take your C7 to the next level in suspension tuning and handling? Introducing the Nitron Pro Race 3 Triple Adjustable Coil-Over w/remote reservoirs. 3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. The remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping. Our World class compression adjuster- means Nitron shocks have the widest range of useful adjustment available on any mono tube gas shock |
ARE YOU READY???
That’s right are you ready to take your C7 to the next level in suspension tuning and handling? Introducing the Nitron Pro Race 3 Triple Adjustable Coil-Over w/remote reservoirs. 3-Way independent damping adjustment. By incorporating our class leading large diameter piston and ultra-strong piston rod, the R3 system demonstrates outstanding levels of performance, damping control and adjustment. The remotely mounted reservoir allows quick and simple independent adjustment of rebound and fast and slow compression damping. Our World class compression adjuster- means Nitron shocks have the widest range of useful adjustment available on any mono tube gas shoc |
