high torque starter???
My 85 starter has to "click" a few times before it starts...doesn't do it all the time, been going on for some time...figured it's about time to replace it anyway, never have touched it....connections seem ok....looking at places that sell them, ecklers etc, they have these "hi-torque starters that promote lower profiles and better performance. Is there any advantage to using one over a good GM OEM starter??? I have a bit more h/p than stock, but nothing crazy....:lurk:
Originally Posted by playsdixie
(Post 1597002718)
..... Your original starter sufficed for 30+ years ... how much more advantage do you need ? ... If you haven't done anything to your engine that dramatically increases the cylinder pressure (compression , hot cam) a standard type starter motor will be more than sufficient ... I would suggest taking yours to a local rebuilder rather than doing a parts store exchange .....
The full size starter on my 86 didn't last too long after I installed headers. A smaller starter is better with headers and about 10 pounds lighter, much easier for us old guys to install.
Best thing you can do is install the 88-91 starter. Its much smaller than the 85-87 behemoth.
It also makes installing headers easier, if you do that. |
appreciate the responses, just one last stupid question...most vendors show the gm starters with a conical end....some of the gear reduction starters have a square end...are they going to fit in my 85??? :cheers:
Yes
Originally Posted by vader86
(Post 1597009953)
Bring your starter to a rebuild place. See what they say. Now if you bring a 6 pack of something decent, they might even be able to "core" it for you towards a newer starter they rebuilt. ONLY IF THEY HAVE A GOOD REP DO YOU DO THAT.
