285s vs 305s
So I got new 285s on my rear but I heard the stock 19s can fit 305s. So in theory a bigger tires is a better tire for grip. But would I even notice the difference?
Originally Posted by Adam Cifonelli
(Post 1597006346)
Originally Posted by Mike's LS3
(Post 1597006380)
The base stock rear rims are 10" and will fit 305 tires with an aspect ratio of "35". However, the 305 tire with an aspect ratio of "30" recommends a 10.5" rim because the tread width is wider and the shoulder of the tire will roll up on a narrower rim. Always check the tire manufactures rim range recommendation. :cheers:
(Post 1597006434)
I just was told it would fit. I dont know much about that stuff. Guess I got some bad info.
(Post 1597006346)
I used 9 inch front rims and 11 inch rears. |
Check this out for proper rim/tire combos:http://www.tyresizecalculator.com/ch...rim-size-chart
As the chart shows a 11 inch width rim is needed for a 305 tire. Yes the 305 tire will fit on a 10 inch rim bit it isn't recommended. |
Originally Posted by irok
(Post 1597006704)
no you didn't get bad info.the 305/35x19 works perfectly on the factory 10" rim
Not recommended! |
(Post 1597006346)
Tread width = better cornering, but less straight line traction Height = better mileage, but less acceleration (gear ratio affected) |
Originally Posted by HOXXOH
(Post 1597008307)
Bigger is better in terms of what?
(Post 1597006434)
(Post 1597008307)
Tread width = better cornering, but less straight line traction Height = better mileage, but less acceleration (gear ratio affected) My straight line tire traction improved going from 285 to 305 rear tires, same tire manufacture just wider tread width. However, a lower profile tire does not benefit straight line traction. But increasing tread width on the same profile will benefit straight line traction. Compare the base with Z51 (285 rear tires) and the GS (325 rear tires), the GS resulted in better 0-60 times. |
If you're looking for drag radials, there aren't a lot of choices in 19" sizes. 305-35-19 Nitto NT05R are a good choice |
Originally Posted by Boomer111
(Post 1597007675)
(Post 1597007697)
[/COLOR]
Not recommended! |
