Is my alternator bad?
I just got my first C4 (an 85) a few weeks ago, I'm still on the learning curve with it. My volt meter is reading 17 volts and there's a red light to the left of it that's on. I think thats too much voltage, that it should be around 13-14 volts. Is the red light next to the voltage reading a warning light? The voltage holds pretty steady though, if the regulator in the alternator was bad wouldn't the voltage be all over the place, wouldn't it keep going up and up as engine speed increases? I'm curious what the volt meters in other people's C4's read so that I can be sure that the alternator is bad (I think it is) before I go and blow the cash for a new one. Any help is appreciated.
Edit: I just put my volt meter on it and its reading 14.5 volts at both the alternator and the battery but the voltmeter on the dashboard is still reading 17 volts with the red light on next to it. I checked it with a second voltmeter just to be sure that I wasn't getting an erronious reading from the first voltmeter and it's reading the same, 14.5 volts. What could be causing the discrepancy in the readings, why is the voltmeter on the dashboard reading 17 volts when the actual voltage is only 14.5? |
Originally Posted by TheGreek!
(Post 1597007203)
Originally Posted by Cruisinfanatic
(Post 1597007226)
Probably bad. Drive over to Advance and they will test it
(Post 1597007269)
I was thinking on bringing it in to be tested (we dont have advance auto out here in Tucson, all we have is O'Reilly's, auto zone, and pep boys and the alternator has to be removed so that they can put it into their test machines). I think it's more than likely bad but I wanted to hear from the people on here first about the red light next to the voltage reading and what the voltages in their cars are.
Live well, SJW |
Do you have an actual voltmeter ?
If yes then go measure batt voltage across the battery terminals with the engine running at idle. Should be right around 14 volts. |
Ok the mystery just deepened. I just put my voltmeter on it and it's reading 14.5 volts at the alternator and 14.5 volts at the battery too but the voltmeter on the dash is reading 17 volts. What could be causing the discrepancy?
I'm going to start a new thread with my findings with the voltmeter but I can't figure out how to delete this thread now that I'm sure that the alternator is good.
(Post 1597007269)
(Post 1597007588)
Don't drive, it is right on top, bring it in and test it,if bad get e new one.
Then check wiring ect. Good Luck |
(Post 1597007466)
If you feel that bad about it, go take it to a rebuild shop and have them check it. I had alternators and starters tested by them that passed but when opened up, you see issues. |
Originally Posted by aklim
(Post 1597009235)
So your Voltmeter says 14.5 and the dash says 17? I'd go with the Voltmeter and forget the dash. My tach hasn't been accurate on it till I got all my gauges calibrated.
(Post 1597009264)
How did you get your gauges on the dash calibrated? Is it even possible to do that? What year is your car?
Mine is a 91 |
