Whining noise
so in the last few times I’ve driven the car has developed a whining noise. It only seens to be audible at 50mph+ and only happens when I’m on the gas. If I let go of the pedal the noise stops immediately. I have ave tried different gears and that doesn’t seem to matter. And it gets louder the faster I go. At 80 it’s pretty damn loud and annoying. Any ideas what would cause this? |
Any Mustangs around?
Did you upset the wife?
:hide: |
I get a severe whine from the passenger seat area whenever I go over 100.
I know what you guys mean .....I hear that same whine sometimes when I'm not even in the car.
In order to hopefully get more serious responses, moving this over to the C5 Tech section.
So assuming you’re home alone and the wife isn’t around, and your ears have stopped ringing from all of the screaming. And you still hear the sound :lol: I just opened up the hood and listened a bit and there is a whining noise from the front of the engine but can’t pinpoint the exact spot. Belts alternator? I’m pretty stumped on this |
Originally Posted by MBVette
(Post 1597025399)
That would make sense since it’s after the car sat for most of the winter. Can you just spray a little bit of white lithium onto them? |
(Post 1597025539)
Is there any specific pulley I should start with to figure this out? Some pullys are obviously much easier to switch out than others |
(Post 1597025944)
Just tested that. And it spins fine but there is a little bit of bearing noise. So I’ll replace that since that’s really quick and easy. And see if it changes anything |
(Post 1597026271)
Well I can spin the things and it just goes and goes for awhile. So I guess it needs to be changed. Lol |
(Post 1597026420)
Ok so when I’m looking around there is a main drive, ac, accessory pulley/tensionwe. Which is that top one on the passenger side that I’m replacing. |
(Post 1597026777)
Ok so when I’m looking around there is a main drive, ac, accessory pulley/tensionwe. Which is that top one on the passenger side that I’m replacing. Accessory Drive http://www.amazon.com/ACDelco-38194-...=ACDELCO+38194 You can get aftermarket brands cheaper. Good time to put a new belt on, if it's never been replaced. |
That’s the one I thought perfect. Just ordered it off amazon so I’ll have it to make the swap this weekend
(Post 1597026820)
