collins48 |
04-19-2018 04:32 PM |
One-of-a-kind custom resto-mod 74 coupe in ohio
30 Attachment(s)
RELUTANTLY, DUE TO HEALTH, I AM OFFERING THIS C-3 FOR $29,900. ENTIRE BUILD HAS LESS THEN 1000 MILES ON THE CLOCK. ORIGINAL B.B. 4 SPEED CAR WITH 26300 ORIGINAL MILES ON ODOMETER. I WILL ATTEMPT TO LIST ALL CUSTOM FEATURES ON THIS CAR STARTING WITH: BODY AND PAINT:ALL WORK DONE BY PROFESSIONAL SHOP THAT SPECIALIZES IN CORVETTES. SIDE MARKERS-REAR GRILLS-AND EMBLEMS REMOVED. FRONT AND REAR BUMPERS ARE FROM ACI FIBERGLASS WITH FRONT BEING 80-82 PROFILE. BUMPERS SEAMLESSLY MOLDED TO BODY. ALL BODY MARGINES TRUED AND PERFECTLY FITTED. ENGINE BAY IS BODY COLOR WITH SMOOTHED FIREWALL INTERIOR COATED WITH LIZARD SKIN HEAT AND SOUND PROOFING. UNDERBODY COATED WITH HEAT COATING IN FLAT BLACK. BEAUTIFUL PAINT IS PPG CRYSTAL CLARET RED WITH RUSSET DIAMOND PEARL FLAMES TOPPED WITH HIGH PERFORMANCE CLEAR COAT. BODY WORK AND PAINT ALONE COST $18,500. CHASSIS: STRIPPED BARE AND 2 COATED WITH EASTWOOD RUST ENCAPSULATOR AND SATIN BLACK TOP COAT. VETTE BRAKE UPPER AND LOWER CONTROL ARMS-VETTE BRAKE FRONT AND REAR FIBERGLASS SPRINGS-STEEROIDS POWER RACK AND PINION STEERING KIT-FRONT SWAY BAR-CARRERA CHROME GAS SHOCKS-OFFSET REAR TRAILING ARMS-DENNYS NITROUS READY HALF SHAFTS-DRAG VETTE CAPTURE STRAPS ON PROP AND HALF SHAFTS-DRAG VETTE STRUT ROD KIT-S.S. FUEL AND BRAKE LINES-DRILLED AND SLOTTED ROTORS-CERAMIC COATED CALIPERS-TUFF STUFF 7 INCH BOOSTER WITH 1.125 BORE MASTER-NEW BODY MOUNTS-LED TAIL AND LICENSE PLATE LIGHT KIT. ENGINE AND DRIVELINE:SHORT BLOCK #3999289 PERIOD CORRECT 2 BOLT MAIN 454 BORED 468 CU.IN. DECKED .020- BALANCED-10.35 FORGED TRW PISTONS-8 INCH FLUIDAMPER BALANCER--FULL ROLLER VALVE TRAIN WITH COMP CAM#11-450-8 ROLLER CAM KIT 290 DURATION-110 SEPERATION-.578 LIFT-CRANE ROLLER ROCKERS-MERLIN WORLD (GRUMPY JENKINS) C.I. HEADS-RECTANGULAR PORT- OPEN CHAMBER-2.3 INT.-1.88 EXT.-119 CC CHAMBERS-COMP SPRINGS-INTAKE GM #3933163 DUAL PLANE WITH 850 HOLLEY CARB-AUTOLITE DISTRIBUTOR-MSD 6AL CONTROLLER-CENTER FORCE DUAL FRICTION 11 INCH CLUTCH KIT-ROD LINKS SPHERICAL BEARING LINKAGE KIT-HITACHI HIGH PERFORMANCE STARTER-COMPLETE MARCH PERFORMANCE FRONT DRIVE SERPENTINE KIT WITH EDELBROCK WATER PUMP- 105 AMP ALT.-SANDEN A/C COMPRESSOR AND TYPE 2 P.S. PUMP-A/C AND HEAT ARE VINTAGE AIR SURE FIT KIT-MOROSO 7 QT. T BOTTOM OIL PAN-2.125 PRIMARY INTO 4 INCH COLLECTOR SIDE EXHAUST WITH GLASS PACK INSERTS COATED IN POLISHED CERAMIC. TRANS IS # MATCHING MUNCIE WITH HURST COMP. LINKAGE-DIFF. IS 3:36 POSI. WITH H.D. COVER. COOLING IS BY BE-COOL ALL. RADIATOR WITH BE-COOL DUAL 11 IN. FANS WITH SHROUD KIT-PAINLESS FAN CONTROLS AND WIRING. WHEELS AND TIRES: WHEELS ARE S.O.B.s FROM CRIS CODDINGTON- FRONTS ARE 17X8.5X4.75 BS- REARS ARE 18X9.5X4.5 BS- TIRES ARE SUMITOMO HTRZs FRONTS ARE 245/45/17 REARS ARE 275/40/18. INTERIOR: ORIGINAL COMPONENTS RECOVERED IN SILVER CLOTH WITH RED HIGHLIGHTS-WOOD GRAIN ON CENTER DASH AND CONSOLE-AM/FM AUTOSOUND RADIO WITH 4 SPEAKERS-POWER WINDOWS-REAR DEFOG-CUSTOM STEERING WHEEL ON T@T COLUMN. ALSO FULL CUSTOM COVER. THIS CAR IS AWSOME AND PICTURES DO NOT DO IT JUSTICE! IF YOU HAVE A SERIOUS INTEREST IN OWNING THIS RIDE PLEASE E-MAIL TO: "collins48@woh.rr.com" google users e-mail to: "collinsjb1948@gmail.com"
