Does race gas benefit the ls3?
I'm running my 2009 ls3 Corvette tomorrow at the track. I've got a 1/4 tank of 93. Would it benefit any putting g a couple gallons of race gas in? How do the O2 sensors hold up? Anyone have any progress with it? Thanks. |
Only with boosted applications. Being I can only get 91 octane here, but can get 100, I do a mix of 91 and 100 to get an average of ~95 and running an eforce at about 10psi.
Originally Posted by Philippians0411
(Post 1597036107)
Originally Posted by HOXXOH
(Post 1597036766)
Any mods, tune, etc? What are expected temps? Chances are good that 93 will be fine. Don't expect anything more to help if you currently don't have any KR.
(Post 1597036766)
My opinion ....
If you have [not] increased the compression of the motor and are [not] running any boost, premium grade gas is all you need especially with the cool ambient air temps you have at this time of the year. No HP gain by adding race gas to the mix. |
Increasing octane will do nothing more than decreasing your wallets' contents. Unless the car has increased compression over stock or you've installed a power adder you may actually LOSE performance by putting higher octane in the vehicle.
Higher octane does not equal more power. Octane rating pertains solely to the fuels ability to resist knock (pinging). U.M. |
Thanks y'all! |
Unless you have a tune for race gas it is not going to help you. |
Stock LS2 with higher compression runs it best on 93 octane.
The stock LS3 with lower compression that the LS2, only needs an octane rating of 91 to run it best instead. |
Originally Posted by Dano523
(Post 1597046532)
(Post 1597046532)
Since you have bolt ons and we are assuming a tune, we can only speculate that you do not have knock retard with 93 octane. If you do have KR present, then yes higher octane will benefit. You should log your runs to answer your question.
I stayed with 93. I have cold air and cat back. Putting headers and 3 in h pipe and some other stuff and tuning it this weekend! I ran an 8.0 at 91 mph! I ran 92 mph one run. Stoked for almost dry rotted(came on car from sitting in garage) and almost bald street tires. https://cimg0.ibsrv.net/gimg/www.cor...b292b024a.jpeghttps://cimg2.ibsrv.net/gimg/www.cor...14f0a9ae7.jpeg https://cimg3.ibsrv.net/gimg/www.cor...01fd6873a.jpeg |
