Willcox Weekend Special 20 off Sale Starts Now!
View The Sale Details Here! Or Go to WillcoxCorvette.com Special Weekend sale Sale! This offer expires Sunday at Midnight! Items Also check out our newest Parts. 1960-1976 Hood Alignment Tool Instructions can be found here. Use this tool to align your male hood bolts to the female striker plate. It cuts the risk of misalignment and stuck hoods and reduces the time to about 15 minutes for both latches. 60-67 68-76 1968-1982 A/C Vent door actuator Link Heater Control Lamp Filter 1977-1982 1977 Delay timer replacement module Now In Stock 1975-1976 Seat Belt Warning Delay Timer This special includes a new special discount code with a lower minimum on the 10, 15 and 20 off. You can only use one code. It's either one or the other and you'll have to calculate which is the best deal. The codes (you can only use one) Willcox20 * New15 * Willcox10 * The details and conditions * Willcox20 : The 20 off code is for most of the entire website... Don't miss out on this one.... Some exclusions apply see below. CA Map products are exempt from this code, use the provided links at the bottom to maximize your savings. See the current flier for the minimum purchase required. New15: The 15 off code is for most the entire website... Don't miss out! ! ! Ca map products are exempt.. that's about it. Other exclusions are listed below. See the current flier for the minimum purchase required. Willcox10: Is good for the entire site with very few limits. See the current flier for the minimum purchase required. The best way to know which code will work is to enter it in the coupon code area and hit "apply code". Select the best code that offers you the best discount. You must enter the code to be eligible, once the order is placed we can not go back and apply a code or change the order. The best way to find interior items when searching the site is to do the following and build your own package! Search this way: A) Enter your year in the year box. B) Enter the color desired in the search box and hit search. The site will then create an index on the left side so that you may select the category you desire. A picture has been added to this sale flier to show you, it's the second picture. and there is a copy posted at the bottom of this flier. To Receive the special discount you must order from the links below. You can place multiple orders and should if you need seat foam and other interior products. Repair and Installation Help Site: We've been working on sorting all the info for you by making categories for each page or manual on this site.http://repairs.willcoxcorvette.com/ Seat covers. Discounted 58-82 covers can be purchased at the links below. Corvette Leather Seat Covers Corvette Leather Like Seat Covers Corvette Mounted Seat Covers Corvette Vinyl Seat Covers Original If you need seat foam, it is only eligible for 10 percent off and it would ship separately so please place a second order for the seat foam at this link. Discounted Corvette Seat foam Corvette Door Panels Can be found at this link! Select the year when you get to the page. Specify year and color when you check out. Corvette Dash pads Can be found at this link! Select the year when you get to the page. Specify year and color when you check out. Other items can be found here: Corvette Carpet Set https://willcoxcorvette.com/media/ca...ew_flier_2.png * products are not those of CA. Exclusions include interior packages, bumper cover, exhaust, fiberglass items that ship oversize, non stock suspension items, Bumpers, and gift certificates are examples. Not eligible for any purchase made prior to this posting. https://willcoxcorvette.com/media/ca...s/e/search.png |
ttt
