RST Twin Disc feels better than stock clutch
This post is just to make a review about the RST Twin Disc McLeod organic Clutch, I had a difficult time researching what was a similar clutch to stock but able to handled 700 rwhp+ Friends recommended me not go with a twin disc because the noise but I wanted make it right the first time.
The McLeod RST Twin Disc (Organic) with steel flywheel the pedal is softer than stock to the point that I though at the beginning that was installed wrong, there is no rattle or noise at all. They have different versions and configuration, I'm talking about the McLeod RST Twin Disc Organic with Steel Flywheel - Part Number: 6405507 and the result may varies with the Aluminum Flywheel or Ceramic version of the RXT |
I have the same clutch and reused my stock ls6 flywheel.
I love this clutch. The initial break in chatter goes away after a couple hundred miles. Would definately buy again. |
Thanks for the review. Hopefully it helps someone in their decision making process.
Sadly I have to say that the clutch failed me, clutch was installed by professionals dedicated just to LS chevy, I followed all the properly break-in instructions and even more for the extra peace of mind. Everything down there was new, mcleod clutch, mcleod flywheel, gm slave, gm master, mcleod pilot bearing, everything.
Apparently seems to be working fine until I decide to test the car to the limit last night and guess what happened, this damn clutch doesn't engage above 5k rpms. All gears work fine, the car runs fine but doesn't engage at high rpms and the smell is terrible. There is no noise, reverse works fine, all gears work fine, I'm lost. |
They need to drop the inspection panel on the bellhousing and check the slave engagement. I have a feeling the clutch is being partially engaged. I've read that can be an issue sometimes.
Probably this clutch may not be good anymore, even if they get to fix it I don't want it back anymore. I'm not doing the labor and is costing me eye and arm, I did everything right to avoid this issue in specific, I thought I was buying one of the best possible clutch there could be and now I have to pay twice for everything again.
is the clutch still new?... if so a tick master cylinder should fix it
Sounds to me like the shop screwed up :eek: That's why I do all my own work. :cheers: Good luck in getting this resolved.
(Post 1597340047)
At the Corvette shop we've installed 3 since I did mine and they all are good. |
i love my rst, had it for about 2k miles ish
I love mine, although I went with a very light flywheel (11 lbs center mass). and it holds at and pulls shifts like the PDK in our other car. Meaning there is no flywheel carrie over when going thru the gears. Then again I don't have 700 ponies.
Do not use an adjustable Slave/Master, it real easy to over extend the PP and cause problems. Mark. |
https://www.summitracing.com/parts/mcl-6932-07
I decided to give it another shot, I just purchased the McLeod RXT Ceramic 6932-07 rated to 1000 hp I know I know, I should have go with the Mantic or Monster but lets believe it was the organic material that was not up to the task. I will keep you all updated as the process take place. Thank you all for your opinions, very appreciated! |
Good luck.
RXT will feel more on/off and less slippy like factory for around town. I'm glad I had none of the headaches you are going through. RST, Fidanza 11lb, new GM slave, Tick master. Feels amazing. |
I don't know the McLeod but have experience with others. Any twin disk clutch is very sensitive to the proper adjustment. If one side is a bit off you won't get full engagement and you'll see symptoms like you described. I see you've ordered the bigger kit now, I just hope they get it installed properly.
my mom drove my car with RST in it, great street clutch
Originally Posted by typeav
(Post 1597079850)
The McLeod RST Twin Disc (Organic) with steel flywheel the pedal is softer than stock to the point that I though at the beginning that was installed wrong, there is no rattle or noise at all. They have different versions and configuration, I'm talking about the McLeod RST Twin Disc Organic with Steel Flywheel - Part Number: 6405507 and the result may varies with the Aluminum Flywheel or Ceramic version of the RXT I installed the RST twin disk with their flywheel and GM Master and slave cylinders about 9000 miles ago now and I haven't had a single issue. I drive mine like I stole it all the time. Have about 425 HP at the rear wheels and am getting ready to run it in the Silver State Classic again this Sept and don't have a single worry when it comes to my RST clutch. I ran it last sept at the Silver state in the Half Mile shootouts and ran 3 runs to 134 MPH at 7000 feet elevation and then drove it home to Kansas City without any incidents. I wouldn't think twice about putting another RST clutch in my FRC. Car 345 |
I'm not saying the RST clutch is a bad clutch, just that is not capable to handle 700 lbs of torque with forced induction.
449 rwhp in dynojet was capable handled by my gm oem stock clutch for 2 years |
after several test in another car we concluded the clutch is faulty from factory
(Post 1597393000)
Originally Posted by leadfoot4
(Post 1597758167)
OBVIOUSLY, you have a highly modified car. Somehow or other, you failed to mention this, in your first two posts. Although it's likely that there MAY have been an issue with the parts, initially, or even the installation, it may also be due to your engine being too much for this particular clutch.
most folks would agree that a built engine was implied. and having the power that the clutch was designed to handle, you'd still expect it to work right the first time. |
