FS: 2001 Chevrolet Camaro SS Street/Strip car, low miles
22 Attachment(s)
while I still dont NEED to sell the car I am more serious about it and have adjusted my price. Keep your negative comments to yourself dont like the car or the price don't look at it , dont buy it.
After 3 years of ownership with my previously 1 owner 2001 Chevrolet Camaro SS I am considering parting ways. This car is the real deal, when I purchased it with 56k miles on MDW 2016 it was a bone stock, clean carfax, 1 owner vehicle. After 15-20k dollars in mods and countless hours of my labor it is transformed into the beast you see today. with just over 58k miles on the clock this car is still a baby ! All mods have roughly under a 1000 miles on them Mods : Performance : -TSP 1-7/8 long tube headers -catless y-pipe -magnaflow dual exhaust -SSRA Ram Air with SLP air lid and blackhawk filter -242/248 comp cam .610/.615 cam; 110LSA (TREX grind) -Comp Cams Trunion kit -Double beehive spring kit with steel retainers -ASP underdrive pulley combo crank and alternator -5/16 pushrods -42lb DW injectors -155LPH walbro in tank fuel pump -EFX custom dyno tune -brand new (50 miles on it ) spec stage 3 6 puck clutch and steel flywheel -pro 5.0 shifter with short stick -MSD 2 -step -SLP Line Lock -Moser Racing Ford 9" rear with 4.30 gears and 33 spline axles spool setup with 1/2" thread extended studs -MSD coil wires -NGK TR55 spark plugs -SLP 180 thermostat Suspension: -BMR non adjustable lower control arms -BMR adjustable torque arm with BMR Trans crossmember and re-location mount bracket -Drive shaft loop -QA1 single adjustable rear drag shocks -QA1 single adjustable 275 spring rate front coilovers Interior: -mini raptor shift light -kenwood double din touch screen radio/cd with ipod connection -interior is in great condition no rips in seats, NO crack in dash -black leather interior -Hurst pistol grip style shifter handle and Hurst white shifter ball -Kee Audio f-body specific speakers Exterior: -8k HID low beams -3k (yellow) HID fog lights -billet front grille -20% tint all around -pewter exterior - please note WELD RT-S drag pack not included with sale (car will have factory GM 17" wheels with matching low mileage tires all around OEM parts: -new AC Delco OEM oxygen sensors -new AC Delco OEM Starter -all Chevrolet OEM gaskets were used on installs -new OEM cooling fans -new OEM coolant hoses -Power steering cooler -rear main seal Flaws: -normal rock chips up front -clearcoat on rear bumper is slightly peeled (from rubber from slicks) -couple of marks on corner of bumpers (must see in person) car runs consistent 11.30s @ etown (spanking H/C/I cars up ) supposedly will run 11.10s-.20s at ATCO. Never got a chance to get the car down there... Car is very consistent and easy to bracket race (despite being a 6MT) FIRM ON THESE PRICES DO NOT NEED TO SELL- SERIOUS INQUIRES ONLY - CASH ONLY (NO TRADES) asking $13,999 slightly negotiable but don't NEED to sell it car can be seen at my repair shop, you can check the car out on the lift if you want no problem Attachment 48352909 Attachment 48352910 Attachment 48352911 Attachment 48352912 Attachment 48352913 Attachment 48352914 Attachment 48352915 Attachment 48352916 Attachment 48352917 Attachment 48352918 Attachment 48352919 Attachment 48352920 Attachment 48352921 Attachment 48352922 Attachment 48352923 Attachment 48352924 Attachment 48352925 Attachment 48352926 Attachment 48352927 Attachment 48352928 Attachment 48352929 Attachment 48352930 |
Solddddd
