Need help with CCM Reprogramming!
After 2 months of trying to determine what caused my 1996 LT4 interior lights/systems to just completely die, I diagnosed as a faulty CCM. CCM's are no longer built and GM does not offer for sale any longer, so I purchased a used one off of ebay, knowing I would have to get it reprogrammed. I installed it and it did fix the problem as it relates to all the systems working; I just can't start the car as the VATS system is preventing it from starting. But, the LCD and all other systems that were dead are now lit up and ready to go.
My understanding is that the CCM must be reprogrammed by a Tech1A. My questions are this:
Thanks, Alan |
Once the miles and VIN are in a CCM it can't be reprogrammed for 'OTHER'. If you're happy with the miles and aren't concerned with VIN I'd suggest you find someone with a VATS INTERROGATOR and have them sort the current CCM 'resistance' and make a new key.
You could do it manually if you've patience. Where are you located? I have an Interrogator and I believe a few others do also. |
So, the VIN and mileage can't be programmed?
I don't mean to disrespect or question you, but I have read on this forum in different threads from multiple people saying the CCM could be programmed; so, now I am really confused. The VIN doesn't bother me so much, but the mileage of this CCM I purchased is 30K more than what the car has, and I plan on selling it. So, that would devalue my car considerably. I have seen a couple of companies online that "reprograms" for $495 or $269; you have to send them your CCM along with the mileage and VIN and they send it back; I wander if they are legit? Or, I could find another used CCM with closer to 78K miles and I would be happy, but I still would have the VATS issue. I haven't read about this VATS Interrogator you mentioned. |
Originally Posted by drcook
(Post 1597149131)
However, I do value WVZR-1's opinion as he is a senior member here. Also take into consideration the statement This rebuild service is performed on YOUR module - |
Originally Posted by Alan Humphrey
(Post 1597148934)
2) Programming is done with the ALDL port. Anybody who repairs and reprogram has a bench setup with the appropriate wires/connectors. 3) Yes the CCM burns the VATS code into memory. Good luck finding out the code on your replacement. A good salvage yard would have given you the code. 4) 100 miles is for new CCMs only. 5) Have no idea who to recommend as you haven't filled out your profile with a location. There are a few of us on the forum with the tools and know how to do the programming. |
Originally Posted by ChumpVette
(Post 1597150430)
1) Once a CCM has been programmed for cats/miles, it can not be reprogrammed. It is locked until wiped and start from scratch.
Product Details Part Number: 211052 Rebuilt: This part has been rebuilt from a core. Selling Unit: each This rebuild service is performed on YOUR module - The rebuild service will repair the faults & check for correct programming of unit (we will require your car's VIN, current mileage, & VATS key code number) - 1 year warranty - Mounts behind radio control head - Accessible under left dash - Remove lower dash panels below steering column & left console trim & side access plate specifically says rebuilt from core specifically says performed on the existing module specifically says the service is to repair the faults says it will check to ensure the unit is correctly programmed |
Did anyone call them and ask?
I'm assuming they wipe the flash somehow, perhaps even replace it, tricking the unit into being "new" again. -- Joe |
We can with our rebuild process. The mileage is not programmable at all, it stored between the ECM and dash as well. The Vats will be blank and there is a setup procedure that will require all keys to be present. We build a bunch of these and the cores are really hard to get so it is a service. You have to send yours in to get rebuilt.
Justin |
Originally Posted by J.Abbott
(Post 1597171826)
You might 'sublet' several but I seriously doubt that they're done 'in house'. |
(Post 1597171826)
Originally Posted by WVZR-1
(Post 1597171956)
I doubt this!!
(Post 1597172301)
Is the mileage just floating around in the wiring?
(Post 1597172970)
I don't remember saying wiring? I did say dash and forgot to put Cluster behind it. Are you asking or being sarcastic?
The mileage is only contained in the CCM. The cluster contains nothing other than a LCD screen that displays what the CCM tells it to. The ECM contains no info regarding mileage. |
(Post 1597172953)
No we do not do these in house, they are done down the road from us from the guy who figured out how to do them and owns about the only machine left to run one on a bench..... YES WE GO THROUGH A TON OF THEM.
-- Joe |
(Post 1597180366)
You are incorrect and this is why most of us vendors stay off and don't come on here to help. Have you heard one person on here complain that a rebuild BCM that we sold them came back to them with different mileage or zero miles on them. The BCM, the gauge module have mileage stored in them. Back in the day when you purchased a new BCM from GM and did not have a Tech 1, how do you think the mileage showed up in it. Maybe it was just magic or the person building the BCM new what car is what going to be sold to and what the exact mileage was when it would be installed. Thank you for proving to me that I made the right decision to come on here and help anyone anymore. It had been awhile and I saw this thread. Good Day
Originally Posted by corvette95
(Post 1597180416)
Wow, you really do not know what your are talking about. Do you know what year the Corvette introduced the CCM (not BCM BY the way). Do you when the Tech1 or Tech1A came out? Looooooong before then. The CCM is the ONLY place mileage is stored from 90 on up. A new CCM (don't know about your reman's) could be programmed with correct VIN, Key resistance , AND mileage for up to the first 100 miles There are minor exceptions about ignition cycles and key resistance. Best not to poke the monster, lot's of knowledgeable people here. We just don't post that often, but you sir are wrong and would do well for your reputation to research this and apologize for posting incorrect information.
From what what you have posted it appears you certainly haven't cracked the code or know what you are talking about, now go on about your business of ruining the few good cores that are out there.
