C6 Z06 brakes installed on 2001 Z06
Finally got around to installing my C6 Z06 brakes on my 2001 Z06. I bought the calipers as take-offs from a 2012 Grand Sport, picked up slightly used stock pads, and the rest of the stuff (rotors, speed bleeders, caliper powder coating, SS brake lines, Motul brake fluid) from TPI Motorsports. They were able to match Millennium Yellow using a color called "02 Vette Yellow".
https://cimg8.ibsrv.net/gimg/www.cor...1ae3ea740d.jpg Stock front brake set up Everything came off fairly easily, with minor trouble getting the new SS brake lines on. New rotors and calipers mounted below :D https://cimg4.ibsrv.net/gimg/www.cor...a535bcede3.jpg C6 Z06 front brakes! https://cimg5.ibsrv.net/gimg/www.cor...6a0240cbd8.jpg Rear set up Once I put the front wheels on, however, I was shocked at the minimal amount of clearance between the spoke and the caliper :eek: . These wheels are TSW Interlagos, 19"x9" front. Everything I read on the Forum indicated that these wheels would clear C6 Z06 brakes, so I did not worry about it until I fit the wheel on. I hand spun both front wheels and noted no rubbing, so I am going to live with it for a while and see how it does. Worse comes to worse, I will buy some small spacers for the front wheels. No clearance issues on the rear (19"x10.5"). https://cimg7.ibsrv.net/gimg/www.cor...76dab0b629.jpg Tight fit! Also bought a carbon ZR1 spoiler from C7 Carbon :cool: https://cimg8.ibsrv.net/gimg/www.cor...5591edd11d.jpg Got everything buttoned up and road-worthy just in time for my local car show on Sunday (I did not win, though :( ) https://cimg3.ibsrv.net/gimg/www.cor...8550c0efb5.jpg https://cimg4.ibsrv.net/gimg/www.cor...e87f107cdd.jpg https://cimg6.ibsrv.net/gimg/www.cor...56db215ea1.jpg https://cimg3.ibsrv.net/gimg/www.cor...2f752be9c4.jpg |
Looks fantastic, nice job on the brakes. Do you notice a firmer pedal? That's my biggest gripe with the brakes. They are strong, but the pedal has a little travel before it firms up. I came from the Porsche world where brake pedals are like rocks, would love to get that feeling back.
Man I have GOT to get rid of the side moldings on my car, looks so much better without them. Beautiful car! |
Originally Posted by mark4cam
(Post 1597170685)
Looks great. Wish my wheels would fit them.
Looks fantastic, Really fills up those wheels! How much of a difference in weight was there between the C5Z rotors and the C6 rotors?
all in all I want to say c6z brakes add about 50lbs total... you can feel the difference in mass at first but you will get used to it and if you add a significant amount of power to the car you won't notice it anymore
You have more clearance than my CCW SP500's have on my C6Z brakes. But if it clears, it clears. The wheel isn't going to change position, and likewise, the caliper isn't going to move either. What I'm getting at is you don't need to worry about a wheel spacer. If it clears now, it clears later.
IIRC, Wilwood recommends a minimum clearance between the caliper and the wheel rim or spoke of something like 0.080". Somethings you have to watch with the location or even have to move the stick on weights. BTW. shape looking Z06!
Great looking Z....pardon my ignorance, after owning a couple of other Vettes I picked up a C5Z:
Direct swap essentially, no brackets needed? |
Originally Posted by ElisTwoCents
(Post 1597222423)
You'll also need larger wheels to clear them. That's what stopped me.
My brake pedal after the swap was firmer, brake grip was near instant. With some modification, you can swap to a larger bore master cylinder, may help with your pedal issue.
I love the yellow, I wish I had went that color on mine. (Went darker red than the way they come) what from lip is that? |
for anyone interested, look into doug rippie's brake lines... they are made by goodridge and use -an fittings instead of banjo bolts... they cost a bit more than others but are worth it in my opinion, they are the nicest and best fitting lines I have used
(Post 1597223290)
Honestly factory brake lines are cheap... Just pick up a set
How well do the yellow calipers match your yellow paint? I’ve been considering also.
i love my C6 Z06 calipers
night and day difference ! https://cimg1.ibsrv.net/gimg/www.cor...65015ba2c3.jpg |
Originally Posted by sabastian458
(Post 1597223256)
...what from lip is that?
Originally Posted by 10thumper
(Post 1598893370)
(Post 1597175794)
