95 LT1 auto: ASR, am I doing it wrong?
Sorry for the dumb question, but is there another system other than ASR that manages traction control? I can spin the tires from a stop if I turn off ASR, but not if I'm turning. The throttle shutdown still activates and doesn't allow the rear end to slide out. I can't tell if brakes are activating, but the throttle shut down is blatant. Is there some other button I'm supposed to push?
Originally Posted by jayjones
(Post 1597172170)
1 Attachment(s)
Originally Posted by AgentEran
(Post 1597172627)
The petal become hard the same way?
(Post 1597172627)
Does the ASR light illuminate when ASR is off and your in a turn attempting to break loose?
the ASR is always turned on by default. once you push the button above the headlight switch the ASR will turn off and a light will show in the driver control center saying "ASR OFF" but even then a stock LT-1 with good tires will have a hard time spinning the tires on clean dry roads. if you have a manual you could dump the clutch at 4K and it should spin them or you could do with a auto too. but that is very hard on the drive line and is a good way to break something
(Post 1597174318)
But OP stated that he can peel out when the wheels are straight. Wouldn't it be easier to break the tires loose with the wheel turned? |
(Post 1597174318)
(Post 1597176789)
In my original post I said the asr is turned off at the switch. At my local track there is a tight turn that even a miata can get the ass to break lose. The c4 feels like traction control is kicking in at that turn, but i've turned off asr. I'm not trying to figure out how to do a donut in the walmart parking lot, just wondering if there is another system interfering in these conditions at the track.
Some of this comes down to driver skill Im sorry to say with no disrespect intended. It took me a long time to understand vehicle dynamics and then use what I learned in a racing environment. As drivers of a big v8 we need to really concentrate on your skills. We are secretly made fun of in miata circles if you arent able to keep up through the turns :) I went though schools where large parking lots were coned off specifically to teach vehicle dynamics. Was really helpful. |
Whats your fuel level. happened to me when it was low.
Very strange. I've got a '96 with an auto and the 3.07 rear end, and I can break 'em loose anywhere, just about anytime. Just yesterday when I was on the mountian road portion of my commute, I had ASR off, and had no trouble getting them to spin on corner-exit.
Fuel tank low, pickup dry?
sounds like fuel starvation to me, try with a full tank and see what happens. I have no problem spinning my 92 around.
Originally Posted by fredk
(Post 1597177180)
Originally Posted by flannel_man
(Post 1597177635)
Originally Posted by kimmer
(Post 1597177712)
Originally Posted by thurman_merman
(Post 1597178212)
This is what I thought reading the first post. In my 91 anything under a half tank would starve the pump. There is an easy fix by using an octane booster bottle or something similar and cutting it to fit around the fuel pump assembly allowing the return line to fill the bottle. Search the forum, there are a couple of how to threads. I've had mine on the racetrack until the reserve light comes on and no starvation.
Thanks guys the fuel was the problem. Fuel starved when turning at 1/4 tank. I feel like that discussion was shifting towards "Is my car powerful enough to slide the rear out" which was absolutely not my question. Filled the tank up this morning and the issue disappeared. Now to find that oil leak.... |
