2014 - GM Letter Re: Potential fuel tank cracks
Got a letter from GM about potential cracks on the top surface of the left fuel tank fuel pump.
It is not a recall but rather a notice that repairs will be done at no charge if the problem occurs. So far mine seems okay. John |
What is your VIN (early or late production?) Mine is very early (#307) and am wondering how many it may affect. Since these vehicles are basically out of warranty by now they must be honoring the repair as a safety issue.
Mines not a 14, but an fairly early 15; I'll post if I also get a letter. #1357
I assume you mean the last 3 letters of the VIN? If so it is 365.
They advise to hang onto their letter and if a problem occurs in 10 year or 193,000 kM they will do the repair at no charge. They will also reimburse anyone who has already paid for the repair. Btw this is GM Canada. John |
Sounds similar to the special 10 year warranty that my 04 for the Cross Over gas tank problem. It also went by VIN number. Only certain VIN numbers were covered. Special warranty only covered Cross Over problem.
This has been going on over past 3 generations.
Couldn't a better material been used for the damned collars? Add it to recurring lousy harmonic balancers. :toetap: At least if it does happen, it's covered. :cheers: |
Originally Posted by Borntorun04/17
(Post 1597180695)
Originally Posted by Landru
(Post 1597180853)
Couldn't a better material been used for the damned collars? Add it to recurring lousy harmonic balancers. :toetap: At least if it does happen, it's covered. :cheers: Must be something in the plastic they use industry wide as my Craftsman riding mower had the problem with the gas tank cracking and leaking at the top. It was about 7-8 years old when that happened. At least, with the mower, it was $50 for a new tank(and gas cap) and took me about 15 minutes to change out(and that included a coffee break midway). I doubt I'll get off that easy if it happens to my 09 Z06. |
Originally Posted by JoesC5
(Post 1597180891)
Covered for the next 3 months on my 09, and then it's my dime that is going to have to pay for another one of GM's screw up.
Tank collors. Fuel senders. AB. Poor MC design. Good grief and none of it's a 'cheap' when fixes start at $2K. I've an '08 Z06, unsold/untitled 'til I took delivery in 03/09. At GM's 10 yr mark now, but also thankfully GMEPP covered 'til '19. Flipping for this one on my dime would severely piss me off. Last thng I'd have guessed hearing was the SOS re tank collars cracking w/ 7s. :cheers: |
2 Attachment(s)
Here's the part that dealer said was bad on my 04. I think he called it BUNG or something like that . Seems different than potential cracks on top surface of the left fuel pump that was stated in OP. Pictures are of 04 fuel system so there's no confusion.
Originally Posted by BlueFinn
(Post 1597179526)
It is not a recall but rather a notice that repairs will be done at no charge if the problem occurs. So far mine seems okay. John Just received the same notice today for my late build 2016 Stingray. Special coverage program 17469 for potential leak from the left fuel tank fuel pump module flange. |
Don't have a letter yet, but 17469 shows up on my GM owner's center. (10 yr, 120,000 mi).
Also have 16009 which is special coverage for a potential faulty fuel tank inlet valve (5yr, 60,000 mi). 2014 built on April 15, 2014. No fuel tank issues to date... |
Mine is a 2017 and I got the letter.
This was a problem so long ago, you'd think GM would have fixed it by now... This is ridiculous... |
Originally Posted by RonC7
(Post 1597182417)
Just got a letter from GM Canada re potential cracks on top of the gas tank for my 15 convert # 21310..special coverage program 17469. Traded this car about 1 1/2 years ago and it was wholesaled to someone in Arizona.
Had to have mine replaced when I had my '14. Took them 3 days to.do the repairs as its quite involved. Basically had to drop everything from the torque tube back.
I had the problem on my 08 they only extended the warranty for that problem to 10 years 120k miles I just made it on mileage when mine was repaired dealer told me it was a $1600+ plus repair :flag:
