84 vette crank no start
Hi there. I posted about this issue a while ago and after doing some more research and implementing some changes I feel better about asking for help on this.
Problem: Vette cranks but won't start. Source: on the 3 pin connector to the wiring harness side of the fuel pump connection there is a blue wire which provides power to the fuel pump. The other 2 are the red wire which provides the float sensor power and the ground wire. The red wire recieves 12 volts strong at the pump and that sensor works. The blue wire for the fuel pump on the WIRING HARNESS not on the fuel pump gets no voltage whatsoever regardless of the key being turned on or not. What has been replaced: fuel sending unit entirely, fuel pump, and fuel pump relay. As i said. The fuel pump is not receiving power but the float sensor is. Since this car is pre-VATS I wouldn't imagine that being a problem. I am looking for advice before i go pulling the whole wiring harness in the car out for nothing. Thanks guys! |
Originally Posted by HPaddic3d
(Post 1597193499)
(Post 1597194657)
Bumping for Monday crew.
Edit: just re-read your post, so you don't have power at the pump. Then I'd check fuses, then the ECM pin that commands pump on. |
(Post 1597194657)
U have a FSM? I doubt the entire harness will ever need pulling.:flag: |
Originally Posted by TheBlaster9001
(Post 1597196646)
There's 12V at the pump, but it isn't pumping/there's no pressure? I've had a bad pump out of the box on my girlfriend's 86, if there's power at the top of the tank and yet it isn't pumping, either the sending unit wiring is bad, or the pump is bad.
(Post 1597196768)
allow me to clarify. There is not 12v at the pump. In fact there is not 12v at the wiring harness connection to the sending unit. It is not the sending unit as i have tested the pump and unit and both are newly replaced and work. There is 12v going to the fuel float sensor which is the wire next to the fuel pump's power supply wire.
Thanks guys. Ill run these fixes and get back to ya.
So im going to hand out sticks for my own flogging. I was testing power at each of the circuit's points and got to the fuse box. The fuse for the fuel pump was shot :crazy: . replaced it and the car fired right up. Sorry to put you all through the hassle for nothing lol.
(Post 1597207596)
(Post 1597207596)
Similarly, a vacuum gauge is a great diagnostic tool! :flag: |
By the way on the fuel pump wiring harness at the fuel pump does indeed have 3 Wires.
One is the RED wire which supplies the pump with 12 volt power to turn on. This wire is a little bigger than the purple. Two is the Purple wire in between the other two, this wire goes to the fuel gauge. This particular wire is smaller than the other 2, it feels like 14-16 awg as not much is needed for the level sensor. Three is a Black wire which supplies ground to the whole mess back there. I have never seen power going to a fuel level sensor. I believe that it is resistance that it measures. When testing my fuel pump I started by powering my connector back there. I had to apply 12 volts at the red wire and then ground the black to get my pump to wake up. Check your Fuse panel near the passengers end of the dashboard for power at every fuse. I experienced corrosion on this fuse block where they looked okay but had no power or current behind them. I would also check the stud behind the battery in front of the drivers door where many of the fusible links get their power from. Like people have said before, get a FSM if you don't have one already. On my year (1988) they had two books to make up the manual. The one that people forget to order is the "Electrical Supplement". Glad to hear that your car is running, now you can go get some smiles per miles again! |
