1996 Corvette changed coil and controller. now won't start
My 1996 was idling rough, but at least it was running. I changed the coil and ignition controller and now it turns over well, but will not start. I put the old coil back in and still will not start. Any ideas would be greatly appreciated.
Codes? Do you have service manuals? Spark, injector pulse, fuel pressure?
1 Attachment(s)
You mention coil and 'controller' - I'll assume 'controller' is module. Correct?
When it didn't run you mention only replacing the coil. You left the new 'controller/module' in place? Brand and part #'s of what you bought? Where did you buy? If 'controller' is actually the module and you've not busted any electrical connections maybe you exchange the module. Coil wire connection? You replaced 1st 1 & 5 but 2nd time only put old #5 back to the car? Attachment 48284261 |
In addition to the advice above, it's worth noting that new replacement ICMs aren't always good. I replaced mine once with a brand new one that was DOA.
Do you have fuel pressure? Test and report back.
..... Also check the electrical connectors for damaged or displaced pins ... the plastic is old and subject to engine heat and will get brittle .....
Originally Posted by C409
(Post 1597198835)
Originally Posted by Southern Boy
(Post 1597200985)
Thank you all for your replies. Just to clarify, I replaced both the coil and the module at the same time. The 1996 C4 (LT1 engine) had been starting reliably but idled rough and was a little ornery restarting once it was warmed up - but it did start after a little cranking. At highway speed it ran well. Once I replaced the coil and the module it refused to start. I replaced the new coil with the original coil and it still refused to start. It seems to be getting fuel as it smells of gasoline after trying to start it. It's a little hard to test the spark as I am a farmer and the nearest neighbor is a few miles away and most are busy like me with spring planting. The pins in the electrical connectors all seem good, but I did notice that the coil electrical connector only seems to have two wires going to it and yet it has three pins. I do have both a Chilton and a Haynes manual for the car, but I find them about as useful on this problem as teats on a bull. Logic says the next step is to put the original module back in the car and see if it starts unless you all have a better idea. Again, I really appreciate your suggestions and follow-up with my questions.
Farmer = DIYer on everything. EBay will have factory service manuals. You need a basic obd2 scanner, spark tester, noid light, and fuel pressure gauge. The spark tester and a good old plug wire will ease atleast checking spark from coil.
(Post 1597200985)
I do have a obd2 scanner and it is not indicating any codes. The idea of how to test spark from pocoW is great and much appreciated. I will give that a shot this evening. I also may have created a problem by slathering dielectric grease all over the 3 plates that are behind the module. I even put some in the plug wire for the coil (to the opti). Is a bunch of dielectric grease too much? With farm equipment grease is your friend, maybe not so much for corvettes. I don't know if clear contact between the module plates and the block is needed for a ground.
You don't want dielectric grease there, you want thermal paste which conducts heat from the ICM.
(Post 1597200985)
Originally Posted by RUU
(Post 1597203448)
Originally Posted by MatthewMiller
(Post 1597203700)
That's correct. However, I doubt that would cause it to fail to even try to start. I could see it causing the ICM to overheat and shut down the car after a minute or so, but when everything is cold it should at least start and run for a bit.
(Post 1597205141)
Thank you MatthewMiller. I was afraid my heavy use of dielectric grease could have shorted something out - particularly the coil to optic plug
There are also 2 pin outs of ICM. The switch was around 94ish, and they will not worth with each other. You may have an early pin out ICM.
Originally Posted by FAUEE
(Post 1597207746)
Thanks to an idea here, I was able to put a spark tester on where I could see it while cranking over the engine. No spark! what could I have done by changing the coil and ICM? The original ICM and coil are back on the car so it isn't a matter of defective new parts.
You need to follow shbox lt1 no start guide.
From memory, to get spark the icm needs a signal from the ecm to send the trigger to the coil. Then the coil woll fore, and send spark thru the opti. So I would check if you'e getting signal to the icm, and then from the icm to the coil. It's an old car, you may have broken a wore during the install. |
