C5 Wider rim fitment
Anyone know if these rims will fit the base C5 OK. They are about 1 inch wider than stock and the backspce is as shown shown:
Stock FRONT WHEELS: Size: 17x8.5 Offset: 56.0 These FRONT WHEELS: Size: 17x9.5 Offset: 54.0 Stock REAR WHEELS: Size: 18x9.5 Offset: 57.0 REAR WHEELS: Size: 18x10.5 Offset: 56.0 Also if you are familiar with this sizing what size tires would make a good fit for the base C5. I would prefer not to have tires past the wheel wells. Just trying to get a little more rubber on the road on a base model. They rims are listed here: https://www.ebay.com/itm/17x9-5-18x1...kAAOSwScJa5ziq |
Those will fit fine. They're ZO6 sizes, and a ZO6 has nothing special body wuse to accomdate larger wheels.
295/35/18 rear 255/40/17 on the front. Could mess with 275 if you don't mind a fatter sidewall. |
Here's a handy width/offset calculator that will tell you how clearances will change: https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Originally Posted by ArtClassShank
(Post 1597202850)
Rims OK - now for some tires
Originally Posted by BURL
(Post 1597200538)
Originally Posted by grantv
(Post 1597203841)
Or 265, factory sizing
Those tires are insanely expensive, not worth the effort or the $$$$ IMO. |
(Post 1597205143)
If I were to buy wheels for a street set up I go 18x9.5/19x10.5-11 as the 295/35 18 is getting hard to find and you can find 295 and 305s in 19s. |
(Post 1597205143)
Am new to this and I apologize in advance if this is the wrong place to ask a question. Trying to figure out tire sizes and the numbers befuddle me. I had 275/30 19 and 305/25 20 on my 1999 C5 Coupe. I would like to go with run flats and am told they do not come in those sizes. Will 275/35 19 and 335/25 20 work without rubbing or hanging out too far?
Originally Posted by Joe5
(Post 1597207242)
(Post 1597205858)
Toyo Proxes in factory sizes aren't that costly...
(Post 1597210011)
Looked on Tire Rack ad there are several Toyo Proxies. Which particular models seem to be the best on the Corvette - Proxie 1, Proxie R1R, Proxie T1 Sport or what? Thanks
Edit... from Toyo.ca |
(Post 1597210011)
Ty
(Post 1597210011)
Originally Posted by 93Polo
(Post 1597210563)
Tirerack only lists 1 Toyo in a 295/35 searching by size
