LT1 Cam swap. It's ALIVE!
https://youtu.be/4u_iecQdOtw
Lloyd Elliot 223/231 .557/.571 110 LSA |
Fixing the link for you:
Sounds mean, did you have him massage the heads too? |
Oh God that sounds fantastic.
Sounds great how long did it take for the swap
Thanks
Originally Posted by gdl2165
(Post 1597201129)
https://youtu.be/4u_iecQdOtw Sounds mean, did you have him massage the heads too? |
Originally Posted by allout1
(Post 1597201764)
Nice work
Not an easy task in the LT1...Sounds great!
Any plans to put it on the dyno? |
Oh my... that sounds fantastic! Did you do the job with the engine in? Or did you pull the job to get it done? I'd love to install an LT4 hotcam in my 92 but am just a little nervous about the amount of work behind it.
Also, is that with the stock exhaust still installed? |
Yes
Yes motor in. Also did oil pan gasket. Had to jack motor about 1" to get cam to slide out. I would recommend custom grind cam over hotcam(old technology)by Elliott Portworks.
Originally Posted by hockeyhead019
(Post 1597202021)
Originally Posted by 9T3VETTE
(Post 1597202010)
Originally Posted by BLKMAMBA
(Post 1597202047)
Yes. I had it dynoed before cam and now will get tuned and re dynoed. Expecting 50whp gain
Where are you getting it tuned? |
(Post 1597202033)
Originally Posted by vette196
(Post 1597202185)
(Post 1597202379)
Gotcha, what is the cost difference? Do you have a build thread or anything like that going through the details? Or was it a pretty straight forward swap as far as following the FSM and just taking your time?
(Post 1597202519)
Modern muscle motorsMotor
I did the same LE2 build two years ago. The only difference is my cam is 227/234. What injectors, TB? I see in your profile 3.54 gears. I went with 4.10, maybe overdone. What TC? I went with 3000stall. BTW, I like the sound of yours much better than mine. Can you elaborate when you say muffler delete? Do you mean no cats, resonator or mufflers?
(Post 1597202784)
where are they located? I googled the name and came up with a place in Il.. I see your in S. NJ, so I was hoping the place you use is north of you
Originally Posted by mrodoc
(Post 1597202886)
