$5,000 350 Build
So you have a running 1972 ZQ3 350 with 50k original miles, and a budget of $5,000. You have the following stipulations:
No biters yet?! Okay, here is what I am thinking
Phase 2 would be adding a Weiand 144 or 177 Supercharger. Still wondering about the stock transmission, and then the rear axle... |
Last initial addition... the car is my dream since i can remember. Mom bought it new in '71 and gave it to me when I graduated college. I have had it for years trying to keep up with repairs. My dad recently built a 2019 Stingray, and I was fortunate enough to meet him across the country for an inaugural road-trip. It was this experience that led me to decide that I must do the full job. It is a a common combination so I am leaning more towards sentimental and drive-ability upgrades as opposed to completely original. Just trying to make sure I don't mess up my plans from the ordering phase!https://cimg8.ibsrv.net/gimg/www.cor...77f9b672d9.jpg
https://cimg0.ibsrv.net/gimg/www.cor...dc8a3e88c2.jpg https://cimg1.ibsrv.net/gimg/www.cor...dad6e8755e.jpg https://cimg3.ibsrv.net/gimg/www.cor...a4e8aee23c.jpg |
With 70cc heads I would use 2 eye brow flat tops, not dished. Good luck with your project.
* Original block fitted with a 383 rotating assembly (eagle or scat would be fine)
* hydraulic roller cam for performance and longevity * if you want to keep the stock iron head look: Engine Quest vortec heads with early intake and valve cover pattern. (about 30 HP better than old fuelie heads) * if you don't mind aluminum heads the new Trick Flow heads that accept all early front drive stuff. * Edelbrock performer RPM with Holley 750 about 435-450 HP & 450 torque |
Can put you in touch with a place that will get you a 10:1 shortblock for under 2k
AFR heads around 1500ish Roller cam setup 1k or less or a good ISky SFT setup for 200 Youll come in under budget. The stroker idea is good, 5k is hit or miss.rarely does a rebuilt 350 feel like youd hope it would it costs hardly any more do add cubes today No way youll do EFI and 383 for 5k. Spend your $ on the best heads possible. |
