TPMS problem
My TPMS shows readings for only 2 tires, the LF and RR. The other two are blank. I tried the training process but could only get the horn sound on the first wheel. Got nothing on the RF tire. Anything else I can try? I have a 2002 coupe. Thanks
Originally Posted by Richard562
(Post 1597209488)
if the same wheel always reads even in a different virtual position you know its the internal tire sensors that are defective. you have been driving the car correct? the tires need to spin to make the TPMS wake up in the tire. |
Originally Posted by 8VETTE7
(Post 1597211047)
:iagree:
Except that you can pull the codes and see if the other sensors are transmitting or not. TPMS Codes will be under B0 - RFA and you will likely see C2105 and C2115 for the two that show blank in the DIC display. |
Originally Posted by bobs77vet
(Post 1597211244)
i always learn something from your posts, thanks bob
I installed Schrader from Rockauto last year in my 02. Yours are likely dead batteries. Did my Malibu with same this year.
