Value question ..... again
All,
I am going to look at a Ruby 40th anniversary tonight with low miles ( less than 40k) A4 with a cracked top. Looking at the prices on here and other places, these cars are all over the board. Guy said he wants to sell it because it never gets driven and it seems like when it does, it always has another issue that pops up. I already have a high number in my head of 8k. What your thoughts? |
Ask these questions:
1. Are there maintenance records you can show me? 2. Happen to have a Car Fax? 3. Any known issues you may have overlooked? Look at these things: 1.Tires 2. Weather stripping (all of it) 3. Interior condition seats, condition & operation 4. Glass 5.All options work PDL, PW, AC, Heater, Stereo, CC, FX3 if equipped 6. Paint Condition/ Panel condition (cracks) 7. headlight operation Test Drive Observations: 1. Listen for odd drive train noises 2. Use your nose to smell for oil burning, sweet smell for coolant when you run the defrost 3. Wheel, drive train vibrations 4. Brakes pulling? 5. Is it aligned correctly? Let go of the wheel on a flat road, does it pull or wander? 6. After youre done, look under the hood for any steam or smoke or leaks etc Ok, now that you have made an assessment of overall condition you can make an intelligent offer that wont insult the seller.I think if the car is in VERY good condition, 8k isnt out of the ball park. If its average like most C4's, more like $6k to $7k depending on how much you think you will need to spend to get it where it would need to be. Good Luck!:cheers: |
Originally Posted by 81c3
(Post 1597257503)
1. Are there maintenance records you can show me? 2. Happen to have a Car Fax? 3. Any known issues you may have overlooked? Look at these things: 1.Tires 2. Weather stripping (all of it) 3. Interior condition seats, condition & operation 4. Glass 5.All options work PDL, PW, AC, Heater, Stereo, CC, FX3 if equipped 6. Paint Condition/ Panel condition (cracks) 7. headlight operation Test Drive Observations: 1. Listen for odd drive train noises 2. Use your nose to smell for oil burning, sweet smell for coolant when you run the defrost 3. Wheel, drive train vibrations 4. Brakes pulling? 5. Is it aligned correctly? Let go of the wheel on a flat road, does it pull or wander? 6. After youre done, look under the hood for any steam or smoke or leaks etc Ok, now that you have made an assessment of overall condition you can make an intelligent offer that wont insult the seller.I think if the car is in VERY good condition, 8k isnt out of the ball park. If its average like most C4's, more like $6k to $7k depending on how much you think you will need to spend to get it where it would need to be. Good Luck!:cheers: Thanks for the reply. |
sweet smell for coolant when you run the defrost |
Originally Posted by drcook
(Post 1597257929)
Also smell down in where the overflow bottle is, down in front of the passenger side tire. The 96 I bought had a pinhole leak due to the plastic side tanks of the radiator. It just now is getting close to 18,000 miles. It isn't a mileage factor but an age factor on the OEM plastic tanked radiators needing to be replace.
I'd do an examination myself, and if I was serious I'd have a trusted mechanic knowledgeable about Vettes give it a pre-purchase inspection. There's too many things that might be wrong or an issue unless it can be put up on a lift, etc. It could cinch the deal, kill it or give you some bargaining power.
My thoughts. |
unless it can be put up on a lift, |
If you refurbed your last vette you should have an idea of what is wrong or needs attention. Condition is key and any kind of records is second. Some people hate getting nickel & dimed to death and should not have an older car.
Guys,
I stopped and looked at it. Talked to the owner. He is the ex-spouse of the original owner. The car has original tire and shocks with 26000 miles on it. He said that he had the fuel lines and fuel pump replaced a couple years ago due to it sitting all the time. It does have a 2 inch crack in the top in the middle and a few scratches here and there where it may have hit a curb with the front. Looks like it got a little battery acid on the one panel next to the battery as well. Weatherstripping seems ok and interior is in good shape. I was thinking of offering 6k, is that going to be an insult? |
(Post 1597257503)
1. Are there maintenance records you can show me? 2. Happen to have a Car Fax? 3. Any known issues you may have overlooked? Look at these things: 1.Tires 2. Weather stripping (all of it) 3. Interior condition seats, condition & operation 4. Glass 5.All options work PDL, PW, AC, Heater, Stereo, CC, FX3 if equipped 6. Paint Condition/ Panel condition (cracks) 7. headlight operation Test Drive Observations: 1. Listen for odd drive train noises 2. Use your nose to smell for oil burning, sweet smell for coolant when you run the defrost 3. Wheel, drive train vibrations 4. Brakes pulling? 5. Is it aligned correctly? Let go of the wheel on a flat road, does it pull or wander? 6. After youre done, look under the hood for any steam or smoke or leaks etc Ok, now that you have made an assessment of overall condition you can make an intelligent offer that wont insult the seller.I think if the car is in VERY good condition, 8k isnt out of the ball park. If its average like most C4's, more like $6k to $7k depending on how much you think you will need to spend to get it where it would need to be. Good Luck!:cheers: I've got a really clean 92 auto with 68,000 miles now. If someone offered me $6k to $7k I'd laugh in their face and say see ya, don't call back. Have a nice day. |
Originally Posted by R254
(Post 1597261625)
Guys,
I stopped and looked at it. Talked to the owner. He is the ex-spouse of the original owner. The car has original tire and shocks with 26000 miles on it. He said that he had the fuel lines and fuel pump replaced a couple years ago due to it sitting all the time. It does have a 2 inch crack in the top in the middle and a few scratches here and there where it may have hit a curb with the front. Looks like it got a little battery acid on the one panel next to the battery as well. Weatherstripping seems ok and interior is in good shape. I was thinking of offering 6k, is that going to be an insult? I'd pass on the car period. There are pristine C4's out there. I paid $9.5k for it. Did it need some work? Yup, cars this old you never know what problem is going to be next. Got about $11k into it now. Drives like a new car, interior is like NEW, paint is what is to be expected (a few chips on the front hood). FX3 (works), sport seats and G92 (must have). |
(Post 1597261625)
He said that he had the fuel lines and fuel pump replaced a couple years ago due to it sitting all the time. It does have a 2 inch crack in the top in the middle and a few scratches here and there where it may have hit a curb with the front. Looks like it got a little battery acid on the one panel next to the battery as well. Weatherstripping seems ok and interior is in good shape. I was thinking of offering 6k, is that going to be an insult? Receipts or not done unless you want to verify. Another $1200 bucks to fix assuming it is acrylic unless you want to send it in for to have the lens redone. And what other damage has that acid done? Why did acid leak? Probably have to replace weatherstripping due to age. Assuming bushings are not dry rotted, I'd check if he has hidden anything from you with your own scanner. Also check compression. Basically, I'd have a PDI done. I would start at $5000 based on the above assuming nothing else is wrong. |
Thanks guys for the insight. The guy was a very nice fella and told me to come back and take it for a good test drive, he said 50 or 60 miles and then make an offer. I guess that is what I need to do.
I paid 9k for my '94 63,000 mile polo green coupe, auto (highway gears) really nice tan interior, working Bose stereo, and electronic climate control. Everything on the car functions as it should. Had new tires, very good original paint one small pea size blemish on driver's seat. It was at a dealer and I couldn't really find a bargaining chip. I think prices may vary regionally too, I've seen similar cars to mine going for 12-14k but from private sellers. I put about 2k into it a couple of weeks after purchase (lower ball joints, oil pan gasket, new starter and battery) at my local Chevy dealer not because I can't do the work but because I don't have time to make it another project. Just my experience, it is an old car despite the obvious care it received prior to my ownership. Good luck.
(Post 1597262410)
Mark |
Originally Posted by Cool Runnings
(Post 1597261706)
In general, I’d say a really clean LT1 C4 is going to cost about $8k-$10k. Now, weather you find one that is already all sorted out and pay that up front, or find an average condition car and pay 6 or 7000 up front then put a couple thousand into it is up to you and also what’s available in your area. But, either way the total investment for a good car is about the same. |
(Post 1597261625)
Guys,
(Post 1597262410)
