Original gas tank - keep or toss?
My car is close to stock but I've kept most everything I've taken off of it over the last 40 years and am now replacing the original and rusty fuel tank with an aftermarket (non-logo) tank from Zip. I can't see any strong reason to keep the old tank, especially considering it's size so am inclined to toss it. Any valid reason to keep it?
Originally Posted by 65air_coupe
(Post 1597283919)
Stuff like that I put on Craigslist once. More to give someone a shot at it if they could use it more than any money I receive. If it is still sealable, someone might want it. I have seen some really nasty tanks made serviceable again. |
There are various products to reseal / line a tank. Personally i have never done it to a car fuel tank but have done many motorcycle tanks with good results. Granted these MC tanks were hard to find and or expensive and a c2 tank is easy to get.
A brand new 100% correct tank is around 200 bucks there is absolutely no reason to try and save a 50 year old tank
Unless you have a '67 tank with the build sticker on it. Then, many save the whole tank, rather than risk taking the sticker off. I've actually seen cars go across the block at Mecum with the original, uninstalled tank festooned with the sticker as part of the package...
FWIW, I had this tank cleaned out and coated 20 years ago. In the end it wasn't worth it, not that it was expensive but I've been plagued with debris from the tank for years now. If it's rusty, replace it!
(Post 1597289452)
My opinion is rusty gas tank = junk = throw away :D
(Post 1597283919)
Toss it out! We don't want old rust in the gas lines leaving you stranded on the road in the middle of nowhere. |
It is one of the most inexpensive things in life that will help you sleep better. No reason not to replace it.
Larry |
